Honda S2000 Honda S2000
Daily Driven S2K
Old Oct 23, 2004 | 02:57 PM
JdmLude04's Avatar
Default Daily Driven S2K
All motor or supercharged s2k a more powerful and reliable daily driver??
Old Oct 23, 2004 | 04:50 PM
PNB's Avatar
PNB
GatorNATION
Default Re: Daily Driven S2K (JdmLude04)
I would assume N/A would be more reliable. However, FI would make more power.
Old Oct 23, 2004 | 05:12 PM
JdmLude04's Avatar
Default Re: Daily Driven S2K (PNB)
How do you like the rsr springs?
Old Oct 23, 2004 | 06:37 PM
Young_R's Avatar
there are many with SC s2k running around that is a daily car. SC dont kick in until higher end of RPM anyway so it should be ok.
Old Oct 23, 2004 | 07:16 PM
JdmLude04's Avatar
Default Re: Daily Driven S2K (Young_R)
As far as more power can all motor lay down as much or more than the supercharger??
Old Oct 23, 2004 | 07:17 PM
JdmLude04's Avatar
sounds dumb but i talked to some people that said they believe you can.
Old Oct 23, 2004 | 07:36 PM
ImportSport's Avatar
Uh no, I have not seen an all motor come anywhere near an SC'd S2K. You can tag 300 hp pretty easily with a decent SC setup. Now if you were just running a plug and play comptech with no aftercooler I could see that being a realistic comparison.
I would go with a conservative SC setup for daily driving. It's going to cost alot less than a full motor build and as previously noted you wont be running as much strain on the engine since it only makes boost at higher RPM.
Old Oct 23, 2004 | 11:25 PM
JdmLude04's Avatar
Default Re: Daily Driven S2K (ImportSport)
sounds good to me...guess gotta get to s2ki and get in on the group buy for the supercharger
Old Oct 24, 2004 | 06:09 AM
Hardtopguy really does give great deals. It looks like your pretty far away from cleveland but I would suggest making the drive for the install as well.
Old Oct 24, 2004 | 08:33 PM
papa5murf's Avatar
as stated above the supercharger doesn't kick in till you hit 6g... just like you were na... but the only difference more power with the supercharger.. ....you just got to make sure you get it tuned.. and you've gotta keep on checking the belt.. to make sure it's not to tight or loose... cuaes that'll cause major problems..
Old Oct 25, 2004 | 10:07 AM
Ahhvtec1's Avatar
No way can an all motor pump out the kind of power a forced fed motor can put out. Best I have seen was 255 on race gas...
Duc
Old Oct 25, 2004 | 11:48 AM
JdmLude04's Avatar
Default Re: Daily Driven S2K (Ahhvtec1)
vafc 2 work for the the tunning?
Old Oct 25, 2004 | 02:58 PM
papa5murf's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JdmLude04 &raquo;</TD></TR><TR><TD CLASS="quote">vafc 2 work for the the tunning?</TD></TR></TABLE>
it works to a certain extent.. remember it's a piggy back system so it's not the best you can get.... some people have pulled out 10rwhp from it... but not much more..
Old Oct 25, 2004 | 06:04 PM
neo1z's Avatar
I certainly wouldnt half-*** tuning my SC'd s2k. AEM EMS
Old Oct 27, 2004 | 07:39 PM
jdmBeast's Avatar
read the new S2000 HyperRev, i believe its #97. J's S2000 hits 320PS... at 8200RPM! so... its possible to get as much power as FI. it'll cost you two broken arms to get it done right like them... "Super NA!"
Old Oct 28, 2004 | 07:54 AM
Nishant's Avatar
Default Re: Daily Driven S2K (jdmBeast)
what 320PS in HP? sorry i don't know the conversion
Old Oct 28, 2004 | 10:24 AM
ceLtic's Avatar
N/A wh0re!
Default Re: Daily Driven S2K (Nishant)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nishant &raquo;</TD></TR><TR><TD CLASS="quote">what 320PS in HP? sorry i don't know the conversion</TD></TR></TABLE>
roughly 320 or so hp..its almost the same
gnxpro24
18
Nov 12, 2014 03:43 PM
I4BangN
Sep 7, 2008 09:39 AM
WH0R3nEF9
Honda S2000
27
Feb 26, 2007 10:39 AM
B18C Turbo
Nov 7, 2006 05:34 AM
03Si
Honda S2000
17
Dec 24, 2004 07:41 PM
