fixed a few things and now car wont start!?
Old Sep 4, 2008 | 09:41 PM
mike93eh2's Avatar
Default fixed a few things and now car wont start!?
wow, im so stumped on this one im posting it on hondatech lol
car is a 92 DX automatic. started and ran fine before i started messing with it.
i replaced the radiator, thermostat, spark plugs, and adjusted the valve clearance. thats it. and now it cranks but wont start..
-it has spark in all 4 cylinders
-it has fuel in every cylinder (plugs are soaked), main relay and fuel pump works.
-cam timing is dead on, tdc mark on crank pulley lined up with mark on timing cover and marks on cam gear lined up with head and "UP" is up
-compression is perfect in every cylinder
-replaced dizzy with known good one
-no cel's
-replaced ecu with known good one
-checked ecu and engine grounds, all are cleaned and good
-checked all fuses under hood and under dash
so after all this it still isnt starting. its obvious its sparking at the wrong time, but HOW? when i have done all the above and its all checked out fine..
this really sucks, i was suppose to be selling this car tommorow and just did a little fixing up on it and now this bullshit had to happen. i really dont know what it could be, id love to hear someone elses answer to this.
Old Sep 4, 2008 | 10:14 PM
salbaje's Avatar
Default Re: fixed a few things and now car wont start!? (mike93eh2)
did you check that the plug wires are on the right firing order??
Old Sep 5, 2008 | 03:27 AM
BearCatRacing07's Avatar
Default Re: fixed a few things and now car wont start!? (salbaje)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by salbaje &raquo;</TD></TR><TR><TD CLASS="quote">did you check that the plug wires are on the right firing order??</TD></TR></TABLE>
X2
Plus check and make sure the gap on the spark plugs are right!!!!
Old Sep 5, 2008 | 06:04 AM
mike93eh2's Avatar
Default Re: fixed a few things and now car wont start!? (BearCatRacing07)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BearCatRacing07 &raquo;</TD></TR><TR><TD CLASS="quote">
X2
Plus check and make sure the gap on the spark plugs are right!!!!</TD></TR></TABLE>
brand new ngk plugs and pregapped. and i rechecked gap aslo
and also forgot to mention the firing order is correct.
Old Sep 5, 2008 | 08:51 AM
mike93eh2's Avatar
ive been working on it again all morning and still nothing. i dont think there is anything left that i ahvent tried. for the first time ever i really dont know what to do.
Old Sep 5, 2008 | 09:13 AM
twinksack's Avatar
* B A N N E D *
Default Re: (mike93eh2)
how do u know the firing order is correct
Old Sep 5, 2008 | 09:26 AM
mike93eh2's Avatar
Default Re: (twinksack)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by twinksack &raquo;</TD></TR><TR><TD CLASS="quote">how do u know the firing order is correct</TD></TR></TABLE>
because ive been working on hondas for over 8 years now.
that and i didnt even touch the plug wires on the dizzy. like i said ran fine before this and now wont start. oem plug wires are even numbered and different lengths.
(distributor) 4 3 2 1 (timing belt)
dizzy (d15b7)
( 1 3 |
( 2 4 |
so now we can totally drop that out of the equation, whats next? i have never been this stumped working on a honda in my life.
Old Sep 5, 2008 | 10:23 AM
mike93eh2's Avatar
it was the distibutor. dont know how because i didnt even touch it and it just went bad overnight. i put another z6 distributor on it and it fires up. no bolt holes lined up so i just vicegripped it on there.
that is really really strange because the b7 dizzy was putting out spark so that means one of the 3 sensors inside wasnt working right but i did the ohm test on all of them and they came out good and also tore apart dizzy and checked everything over and its fine. but now i guess i just need a new dizzy unless i just put the z6 internals into the b7 dizzy housing.
Old Sep 5, 2008 | 12:11 PM
twinksack's Avatar
* B A N N E D *
the coil probably went out
Old Sep 5, 2008 | 12:45 PM
mike93eh2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by twinksack &raquo;</TD></TR><TR><TD CLASS="quote">the coil probably went out</TD></TR></TABLE>
it was sparking in every cylinder. just not at the right time. so now the coil wasnt the problem. i just stated above what the problem was.
aeon117
Aug 20, 2016 07:46 PM
Hill4589
21
Jun 20, 2009 05:27 PM
free99
Mar 18, 2008 10:52 AM
vinuneuro
Oct 9, 2006 10:36 AM
