cruise control removel......
Old Sep 4, 2008 | 09:13 PM
DiMpL3s.'s Avatar
Default cruise control removel......
I did alittle searching and didn't find much...
was wondering if anyone knew of a good write up before u just rip everthing out and cut the line coming from the firewall...
thanx
Old Sep 5, 2008 | 08:03 AM
IN VTEC's Avatar
Default Re: cruise control removel...... (DiMpL3s.)
If this is for a 3rd gen, you don't need to cut the line from the firewall. That's the hilljack way of doing it.
You can twist the plug to release it from the firewall and then disconnect the end of the line from the top of the pedal.
After that, it's just three M6 bolt-washers and one electrical connector.
Old Sep 6, 2008 | 03:01 PM
DiMpL3s.'s Avatar
Default Re: cruise control removel...... (IN VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IN VTEC &raquo;</TD></TR><TR><TD CLASS="quote">If this is for a 3rd gen, you don't need to cut the line from the firewall. That's the hilljack way of doing it.
After that, it's just three M6 bolt-washers and one electrical connector.</TD></TR></TABLE>
ty
Old Sep 7, 2008 | 10:02 AM
EnjoyTheRideDC2's Avatar
Might as well remove the Cruise Control Computer mounted behind the drivers side kick panel, towards the firewall too.
Old Sep 7, 2008 | 10:14 AM
DiMpL3s.'s Avatar
Default Re: cruise control removel...... (EnjoyTheRideDC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EnjoyTheRideDC2 &raquo;</TD></TR><TR><TD CLASS="quote">
Might as well remove the Cruise Control Computer mounted behind the drivers side kick panel, towards the firewall too. </TD></TR></TABLE>
ty again
runsfromdacops
Feb 1, 2010 06:48 AM
B16b-EJ8
Jan 28, 2007 05:53 PM
GForceInteg
Jun 6, 2005 01:19 AM
biglew
Dec 29, 2003 08:45 PM
