Transmission & Drivetrain Gearboxes, Differentials, Clutches
assembly of b16 tranny?
Old Sep 4, 2008 | 08:23 PM
orioncivic's Avatar
Default assembly of b16 tranny?
im on the last step of rebuilding my trans. and i cant seem to get the snap ring to go in the groove of the bearing? its deff. around the outer cir. of the bearing but will not slide down. there is a gap in the seat of the casing where it seems the bearing should seat into. i just replaced the bearing and snap ring. also i cant find the torque for the case bolts? anyone have any ideas?
Old Sep 4, 2008 | 08:34 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: assembly of b16 tranny? (orioncivic)
if the snap ring is around the outer race fully, then that is not keeping the case from completely closing.
Take a long screwdriver and pry the counter shaft up into the snap ring groove(from the opening)
Old Sep 4, 2008 | 08:37 PM
Aquafina's Avatar
If the snap ring is spread around the CSB but not in the groove, do not tighten the case bolts. Bad things can happen when you do that.
Do as EVS said. Case bolts are 20 ftlbs.
Old Sep 4, 2008 | 08:44 PM
orioncivic's Avatar
Default Re: (Aquafina)
case is fully seated the ring is not on top of the bearing(i broke the bearing thats why i had to replace) ill try the prying in a bit
Old Sep 4, 2008 | 09:04 PM
Mista Bone's Avatar
D Tranny Guru
if the cases have mated, CS ring properly expanded but just not locked in, flip the tranny over, listen for the click.
Gravity is a wonderful thing.
Old Sep 5, 2008 | 08:34 AM
orioncivic's Avatar
Default Re: (Mista Bone)
tried that and no go. it moved closer but not enough. tried prying with a screwdriver, but that didnt work either. is it possible to have tightened the nut down too far? or pressed the bearing down too far?
Old Sep 5, 2008 | 08:55 AM
Aquafina's Avatar
No.
Old Sep 5, 2008 | 09:17 AM
Evs-One's Avatar
Solbros Owns Me
Default Re: (orioncivic)
pictures say a thousand words...
Old Sep 5, 2008 | 10:59 AM
orioncivic's Avatar
i got it had to bump it on the floor instead of the bench. thx for the help guys!
Old Sep 6, 2008 | 05:02 PM
Blown90hatcH's Avatar
Just make sure prior to attempting to tighten/closing the cases that the snap ring is spread apart. If so and you have the cases mating now. Put half the bolts in snuggly. Flip it over and gently boune it on a couple thick phone books.
Old Sep 6, 2008 | 08:33 PM
96Spec Ek's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mista Bone &raquo;</TD></TR><TR><TD CLASS="quote">if the cases have mated, CS ring properly expanded but just not locked in, flip the tranny over, listen for the click.
Gravity is a wonderful thing.</TD></TR></TABLE>
fobile missile
Mar 10, 2006 10:44 AM
Lmgrcivic
Oct 10, 2005 07:43 AM
ultimatehonda
Apr 30, 2004 08:03 AM
tilt
Feb 5, 2004 07:19 AM
integra95
Jun 30, 2003 05:32 AM
