Help: Problem Starting Car with Hondata
Old Jul 24, 2002 | 02:56 PM
ElectronMan's Avatar
Default Help: Problem Starting Car with Hondata
I have a '99 Civic Si with Greddy Turbo, 450cc injectors etc and I've recently installed a Hondata Stage 2B with datalogging. I'm having a problem everytime I start my car. I has to turn over several times and I have to blip the throttle a bit to get it to start. I adjusted the TPS voltage to .45V last night, with the car not running, hoping that would fix it but it did not. Any help would greatly be appreciated?
[Modified by ElectronMan, 11:57 PM 7/24/2002]
Old Jul 24, 2002 | 03:34 PM
PrecisionH23a's Avatar
Default Re: Help: Problem Starting Car with Hondata (ElectronMan)
which base map did you get with it?
Old Jul 24, 2002 | 04:11 PM
symba's Avatar
Default Re: Help: Problem Starting Car with Hondata (GudeH23a)
Gude, aren't you running with Hondata? What is your Hondata setup? which ECU do you have and did you find it all you had hoped for? I'm trying to decide between Hondata and AEM EMS.
Old Jul 24, 2002 | 04:16 PM
dustin's Avatar
I'm gonna guess the hondata has a base map for stock injectors, holding the throttle down leans everything out....
Old Jul 24, 2002 | 08:26 PM
Default Re: Help: Problem Starting Car with Hondata (dustin)
The base map is from the tunes library, the Greddy Turbo B16A with 440's. I'm running 450's though.
Old Jul 24, 2002 | 09:13 PM
Default Re: Help: Problem Starting Car with Hondata (symba)
im not running the hondata yet, i will be in the next few weeks though. im running the p75 integra LS ecu, ill let you know how everything runs. i chose hondata because of the dyno shop im going to have tuning it down to a science, next summer i probably will run the AEM EMS once it is more familiar to tuners and has all of the little kinks worked out.
Old Jul 25, 2002 | 01:33 PM
Do you know a guy a Clemson named Sam with a '91 MR2 Turbo?
Old Jul 25, 2002 | 01:35 PM
yep
Old Jul 25, 2002 | 02:48 PM
Ahh just curious, he's a good friend of mine.
bcp0715
Acura TSX
Apr 13, 2013 05:14 AM
crxb16a90
Engine Management and Tuning
Aug 10, 2009 08:13 AM
Smashback
Mar 8, 2003 05:19 AM
RosSi
Nov 16, 2002 07:48 PM
