Running on 3 cylinders not sure why????
Old Sep 2, 2008 | 08:20 AM
BlakeJ53's Avatar
Default Running on 3 cylinders not sure why????
The car is a 94 civic dx all stock. The car was not starting so I replaced plugs wires and distributor with a new one from autozone and cap and rotor. The car starts but it is only running on 3 cylinders. It is getting spark on the number 4 cylinder because I pulled the plug and put it on the head and there was spark it was blue but when I hold it an inch away no spark. I also pulled the fuel rail to check and see if the injectors were firing and they were. Should I just replace the distributor again? I will be doing a compressions test later today.
Old Sep 2, 2008 | 01:29 PM
BlakeJ53's Avatar
Default Re: Running on 3 cylinders not sure why???? (BlakeJ53)
anyone??
Old Sep 3, 2008 | 07:20 AM
BlakeJ53's Avatar
anyone?
Old Sep 3, 2008 | 08:03 AM
davefromPA's Avatar
let us know how the compression test comes out and then we should be able to help.
Old Sep 3, 2008 | 08:32 AM
wicked_gk's Avatar
probably a cylinder misfire. i have the same problem
Old Sep 3, 2008 | 03:56 PM
BlakeJ53's Avatar
Default Re: (wicked_gk)
Compression test is as follows from 1 to 4 . 160-158-170-130. defintently a dead cylinder
Old Sep 3, 2008 | 04:03 PM
Mugen112's Avatar
That doesn't look like the greatest numbers I've ever seen, however they don't look like they would cause a dead cylinder. Try a leak down test and see what that yeilds.
Old Sep 3, 2008 | 04:11 PM
91gst's Avatar
Default Re: (Mugen112)
yeah, those numbers arent terrible enough to cause a dead cylinder. I have a 93 dx that was on three cylinders with spark and fuel to all four and i did a compression test with 162 165 160 25. Cylinder number 1 was dead completely. It turned out to be a chipped valve which I didnt find out till i pulled the head off.
Also do a valve adjustment and make sure everything is within spec. I spent a whole month troubleshooting a misfire in my integra and it was because I didnt adjust the valves after my rebuild. I never did a compression test but i did everything else.
Good luck!
eg:R
Dec 26, 2013 07:41 PM
AxeOfGlory
Sep 25, 2013 06:28 PM
BoltonGSR
Apr 11, 2009 02:53 PM
Streetracer4life128
Jul 2, 2006 03:12 PM
LSVTEC 91 Civic
25
Jul 12, 2004 01:49 AM
