Fixing a misfire?
Old Apr 3, 2009 | 10:43 AM
BoltonGSR's Avatar
Default Fixing a misfire?
Yes i know it should be an easy search but the search function is now trash..
I dont have my helm what are some common methods to fixing a cylinder misfire?
Old Apr 3, 2009 | 11:16 AM
dominicanluimi's Avatar
Default Re: Fixing a misfire?
It could be a few things my girls 98 ls was throwing 4 codes for misfire. Gapped the spark plugs. problem fixed. Also check wirer, distributor, rotor, ignition coil,injectors and valve adjustment
Old Apr 3, 2009 | 01:25 PM
2k1_gsr's Avatar
my car is actually getting fixed for that right now... i tried the plugs, wires, and dizzy, it didnt fix it. i did a leakdown test and it showed cylinder 1 & 3 were messed up. now i have to rebuild. goodluck tho it could be something else for you.
Old Apr 4, 2009 | 07:21 AM
bada9's Avatar
check spark, fuel, and compression/leakdown tests...should point you in the right direction from there
Old Apr 7, 2009 | 02:47 PM
BoltonGSR's Avatar
I did a compression test. All the cylinders were around 180..
Checked the plugs
Checked the wires
I guess what I have left is the distributor and injectors...
Old Apr 11, 2009 | 02:53 PM
BoltonGSR's Avatar
Ok I found the problem.
The injector with the misfiring cylinder was cracked...
Thanks
blueberryEG
Jan 25, 2014 12:55 PM
hondalord
May 27, 2010 08:42 PM
jdm_sai
18
Feb 16, 2010 05:19 AM
BlakeJ53
Sep 3, 2008 04:11 PM
Tom123456
Aug 23, 2006 03:13 PM
