overheating problem HELP!!!
Old Sep 2, 2008 | 06:56 AM
vinceiscoo's Avatar
Default overheating problem HELP!!!
i just got a eg6 coupe.
and its overheating.
it has a d16zc motor.
it only overheats when i have the a/c on and stopped, but when im moving it doesn't overheat
what do you think is the problem?
Old Sep 2, 2008 | 06:59 AM
vtecb18c's Avatar
Default Re: overheating problem HELP!!! (vinceiscoo)
probably a bad thermostat...this may sound stupid but did you check your fluids to make sure your not low on antifreeze or 50/50 whatever your using?
Old Sep 2, 2008 | 10:57 AM
vinceiscoo's Avatar
Default Re: overheating problem HELP!!! (vtecb18c)
The previous owner used only water.. Do you think that could have created the problem.
Should i do a coolant flush?
Old Sep 2, 2008 | 11:09 AM
SeVeNisOnE's Avatar
What do you have in it now? You shouldn't use only water on a daily driven car. Make sure you have enough coolant in the hoses. I usually use a mixture of 30% coolant / 70% water since water dissipates heat faster than coolant does. I wouldn't run water only unless you are racing the car at an event and replacing the water with a coolant mixture afterwards. Coolant/Antifreeze acts as a lubricant for the cooling system. Make sure the car is warmed up when adding more coolant so the thermostat is open and make sure your heater is on hot so the coolant also runs through the heater core. Check your thermostat to make sure it opens. If the thermostat is fine, make sure you have enough coolant. If you have to regularly replace the water in the cooling system you may have a leak or the head-gasket is allowing coolant in the cylinders if you have smoke coming out of the exhaust. It wouldn't hurt to flush the system. It common for the car to cool when your driving since cool air is running through the radiator, but when your standing still the car is relying on the fan to get as much as it can through the radiator and sometimes its just sucking hot air through it. So there are a lot of things you can check for, but start with checking the coolant level and what is in there for now and get back to us. Again make sure the car is warmed up before you add more coolant and that the heater is set to hot.
Old Sep 3, 2008 | 10:31 PM
vinceiscoo's Avatar
Default Re: overheating problem HELP!!! (SeVeNisOnE)
hey thanks for all your guys help
ima just bring it to the shop and get a coolant flush and have them check me thermostat
Old Sep 3, 2008 | 11:05 PM
obuhmyuh's Avatar
just check ur coolant levels, here's a DIY.
1)pop hood
2)open radiator cap (front/passenger side of bay)
3)look inside
if it's good, end here, and check your radiator fan and it's fuse, and if those are ok check you're thermostat ($10 at autozone)
4)add coolant and put cap on and shut hood.
Old Sep 3, 2008 | 11:22 PM
vinceiscoo's Avatar
Default Re: overheating problem HELP!!! (obuhmyuh)
when i first got the car i open the cap and turn the car on and let it warm up, there was alot or air pockets, so i added coolant but its still doing it.
Old Sep 3, 2008 | 11:25 PM
obuhmyuh's Avatar
theres also a bleeder valve with a 12mm head on it, if you follow the upper hose toward the radiator you can find it, you can loosen that with the car running to get the bubbles out and ensure that its pressurized correctly.
Old Sep 4, 2008 | 07:23 AM
vinceiscoo's Avatar
alright thanks i let you know what happens after
Old Sep 4, 2008 | 08:13 AM
bf97ek's Avatar
are your rad and condenser fans both working? could be temp sending unit.
Old Sep 4, 2008 | 07:58 PM
vinceiscoo's Avatar
Default Re: overheating problem HELP!!! (bf97ek)
yea my fans do work and whats rad?
and how can i check the temp unit?
Old Sep 4, 2008 | 11:07 PM
obuhmyuh's Avatar
rad = really cool
but in this case its short for radiator
Old Sep 5, 2008 | 11:02 AM
vinceiscoo's Avatar
yea thanks
i think both are working
ill let you know
to busy with school and work
zpower
Nov 21, 2012 04:15 PM
dth0ng69
18
Jul 19, 2009 09:12 AM
toohott4handlin
21
Feb 8, 2004 03:47 AM
TurBoXBirD16
11
Mar 20, 2003 01:55 PM
Andrew Sites
Oct 7, 2001 08:36 PM
