ef overheating
Old Sep 1, 2008 | 11:08 PM
E_F_9's Avatar
Default ef overheating
90 civic hatch, has new waterpump,"new" head and new headgasket,new waterpump,removed thermostat,new radiator cap and swapped radiator for one without problems. i drive for about 10 minutes and it begins to overheat with fan on. Doesnt matter if im sitting or driving.Noticed today the top radiator hose was hot and the lower was "cold".Im lost...i was told before it was not very likely for there to be a clog in the block but its seeming more and more likely to me.
Old Sep 2, 2008 | 07:02 AM
zccr-xsi's Avatar
maybe u got a blocked water passage in the head or block?have u ever thought about giving the system a good flushing?i know this is dumb *** question but how well did u bleed the system?and u sure it aint leaking in places u can see that the water pipe backside of the thermostate housing?
Old Sep 2, 2008 | 03:03 PM
E_F_9's Avatar
3 different heads so probably not the problem, block is a possibility,bled the system and no leaks
Old Sep 2, 2008 | 05:57 PM
zccr-xsi's Avatar
have u try taking out the thermostate and see if it still overheated?
Old Sep 3, 2008 | 02:53 PM
E_F_9's Avatar
that was the first thing i did
E_F_9's Avatar
maybe my new water pump is a pos
Old Sep 3, 2008 | 06:13 PM
zccr-xsi's Avatar
is it leaking out the seep hole?
Old Sep 3, 2008 | 07:04 PM
E_F_9's Avatar
nope..flushed it and didnt seem like anything was clogged..had another friend come by and check it out too...No luck,couldnt even get it to start but once after flushing and it ran like crap..i think somethings up with the block SO pulling the motor this weekend im tired of messing with it.
Old Sep 4, 2008 | 04:48 AM
zccr-xsi's Avatar
thats whtas i said the first time maybe u got something stuck in the water passges of the block
h22a2JZGTE
Feb 25, 2013 07:13 AM
chawski
Honda Civic (2001 - 2005)
Sep 5, 2011 09:38 PM
H22EKHATCH
Jan 22, 2010 07:59 PM
sh4mr0ck
Sep 26, 2008 12:15 PM
MPALUGHI
Aug 15, 2005 12:40 PM
