vtec not crossing over
Old Sep 1, 2008 | 08:04 PM
dchatch's Avatar
Default vtec not crossing over
was drivin my car to work the other day, and i noticed that when i got to about 4400-4500 rpms vtec wasn't crossing over....i've been having issues with my IAC/vaccum leak...haven't quite figured it out, i'm stuck on whats causing this...i'm throwing a CEL, but it could be multiple things that have been going on with the car...i have a 92 civic swapped with a 99 b18c1...converted to OBD1
Old Sep 1, 2008 | 11:18 PM
civic95hbvtec's Avatar
Default Re: vtec not crossing over (dchatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dchatch &raquo;</TD></TR><TR><TD CLASS="quote">was drivin my car to work the other day, and i noticed that when i got to about 4400-4500 rpms vtec wasn't crossing over....i've been having issues with my IAC/vaccum leak...haven't quite figured it out, i'm stuck on whats causing this...i'm throwing a CEL, but it could be multiple things that have been going on with the car...i have a 92 civic swapped with a 99 b18c1...converted to OBD1 </TD></TR></TABLE>
You said it, throwing codes and could be multiple things DUH
Check the codes bird brain
Old Sep 2, 2008 | 06:59 AM
zccr-xsi's Avatar
VTEC WONT ENGAGE for many resaons!!did u jump it and see what codes its throwing?and if your vtec is enageing at 4500 are u useing a chipped computer?cause stock crossover is 5k in most cases.
1.low on oil
2.ecu showing codes
3.vtec not hooked up right
Old Sep 4, 2008 | 01:27 PM
dchatch's Avatar
Default Re: (zccr-xsi)
i'm throwing codes 22 and 23, i know code 23 is the knock sensor....but i dont know what code 22...checked the oil...was low by about half a quart
Old Sep 4, 2008 | 06:01 PM
zccr-xsi's Avatar
fill it up with it up with oil, fix your vtec codes andfix the knock reset the ecu and try again.
FYI your crazy as hell running a b-series that low of oil!!!
Old Sep 6, 2008 | 07:37 AM
dchatch's Avatar
tell me about it...i've never let the car go that low...off topic question, i bought this motor, tranny, and ecu and i've noticed v-tec crosses over at 4500....i thought that was the factory crossover point, how would i know if this thing was chipped
Old Sep 6, 2008 | 04:54 PM
zccr-xsi's Avatar
Post a pic of the ecu ill tell u if it is chipped.
Old Sep 12, 2008 | 09:36 AM
AMG's Avatar
AMG
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zccr-xsi &raquo;</TD></TR><TR><TD CLASS="quote">FYI your crazy as hell running a b-series that low of oil!!!</TD></TR></TABLE>
And why would this be any worse than any other motor? A half-quart, although not good, is not "crazy as hell" bad.
And if your check engine is on, vtec won't engage in most all cases.
Old Sep 13, 2008 | 07:49 AM
King V's Avatar
Default Re: (AMG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AMG &raquo;</TD></TR><TR><TD CLASS="quote">And if your check engine is on, vtec won't engage in most all cases.</TD></TR></TABLE>
Not really true. I've got a CEL for catalyst efficiency low, and VTEC works fine.
Old Sep 13, 2008 | 07:51 AM
zccr-xsi's Avatar
Default Re: (King V)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by King V &raquo;</TD></TR><TR><TD CLASS="quote">
Not really true. I've got a CEL for catalyst efficiency low, and VTEC works fine.</TD></TR></TABLE>
caUSE its a soft cel.it would depend on what code its throwing.if its in limp mode forget it vtec wont work.
EK FLY
Aug 24, 2006 05:30 PM
schardbody
Jan 20, 2006 07:19 PM
hondaracing1
Jun 29, 2005 08:47 AM
97gsrEK
20
Dec 27, 2004 08:54 PM
00WhiteEKy
Sep 10, 2002 02:58 PM
