HELP!!!HELP!!!HELP!!!2000 si
Old Sep 1, 2008 | 01:13 PM
needmoreboostem1's Avatar
Default HELP!!!HELP!!!HELP!!!2000 si
Im having problems with the RPMS and the speedo in my 2000 civic si, I just swaped a turbo gsr into, the RPMS start to jump all over the place after about 5000 to 5500r and the speedo just wont work. the speedo did work for about 5 mins one time but then nothing. I swaped the cluster out with a friends but nothing really changed, and the speed scener worked in my last shell so I dont think its that. Also wondering why heater will not blow hot air ??? Any info will help thank you.
Old Sep 1, 2008 | 05:44 PM
vtecb18c's Avatar
Default Re: HELP!!!HELP!!!HELP!!!2000 si (needmoreboostem1)
sounds like its a wiring issue...what obd is the motor??
Old Sep 1, 2008 | 06:08 PM
Default Re: HELP!!!HELP!!!HELP!!!2000 si (vtecb18c)
obd1
Modified by needmoreboostem1 at 8:17 PM 9/1/2008
Old Sep 1, 2008 | 06:12 PM
vtecb18c's Avatar
make sure theres no wires detached or de-pinned from the jumper harness and check all of your ground wires....it could be an ecu issue is it throwing any codes?? are you running a chipped p28?
Old Sep 1, 2008 | 07:28 PM
its a p28 tuned on chrome, no CEL's. checked all the fuses and all the grounds that i could without pulling the dash. ill be checking the jumper harness next.
Old Sep 1, 2008 | 11:10 PM
civic95hbvtec's Avatar
Jumper harness is a good idea....
The VSS reads good at the ECU so we know
its good.
Any diagram for the cluster wires colors ect ect ? then we can check with a volt meter.
Wiring diagrams for dash harness please ? ??
Bump it up !
Old Sep 2, 2008 | 08:16 PM
srmofo's Avatar
Default Re: (civic95hbvtec)
bleed the coolant with the heater running, you may have to remove one of the heater hoses and fill with coolant, everthing else to lazy to read right now
Old Sep 2, 2008 | 11:34 PM
Default Re: (srmofo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by srmofo &raquo;</TD></TR><TR><TD CLASS="quote">bleed the coolant with the heater running, you may have to remove one of the heater hoses and fill with coolant, everthing else to lazy to read right now</TD></TR></TABLE>
Allready did
Old Sep 3, 2008 | 06:25 AM
srmofo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic95hbvtec &raquo;</TD></TR><TR><TD CLASS="quote">
Allready did</TD></TR></TABLE>is the cable that controls the flow hooked up and not damaged? inspect closely because they are easy to fubar
Old Sep 3, 2008 | 12:31 PM
looked good but i will mess with it today.
didnt look like it was moving enough maybe.
Old Sep 7, 2008 | 09:25 PM
ttt
Old Sep 13, 2008 | 04:06 PM
TTT
We fixed the heater !
Still no tack and rpm's hop around like crazy.
This is a gay problem at 15psi !
About to yank dash, any ideas ?
Old Sep 13, 2008 | 04:10 PM
slomofo's Avatar
GDD Member
What color are the wires going to your IACV, MAP, and TPS?
Old Sep 15, 2008 | 03:55 PM
stock 2000 si harness with a obd1 gsr swap.
Old Sep 25, 2008 | 01:48 PM
TTT
still got no speedo and tack is jumping around
Old Sep 25, 2008 | 03:20 PM
slomofo's Avatar
GDD Member
Change your ignitor and your coil, then the problem should go away.
dohc_star
Engine Management and Tuning
Jan 26, 2012 09:38 PM
hialeahzbg
Jun 12, 2011 10:18 PM
zeroek
Jun 22, 2005 05:30 PM
2k1_ITR_0736
Apr 12, 2003 11:25 AM
vtec69
11
Dec 1, 2002 06:05 PM
