idling issue
Old Aug 31, 2008 | 02:34 PM
one-cam's Avatar
Default idling issue
just swapped an a6 into a 93 civic sedan i fired it up and the rpms are bouncing up and down. from 1k to 3k rpm. any suggestions?
Old Aug 31, 2008 | 02:37 PM
dohczccrx's Avatar
Default Re: idling issue (one-cam)
need alittle more info on the setup. what wire harness intakemanifold and all thing that would affect idle
Old Aug 31, 2008 | 03:12 PM
HondaGuy951's Avatar
go with the obvious idle air control valve......then vaccuum leaks ect.
Old Aug 31, 2008 | 03:16 PM
vtecb18c's Avatar
Default Re: idling issue (HondaGuy951)
why the hell would you need more info...either its the IACV(which was mentioned), possible vacuum leaks(like was mentioned also, ot the TPS...those are usually the culprits and if not than its usually an ecu problem...so any wire harness, intake mani, model, make, year their all pretty irrelevant to the problem
Old Aug 31, 2008 | 03:21 PM
one-cam's Avatar
Default Re: idling issue (vtecb18c)
i used the stock d15b7 wiring harness that came on the car.. previous owner decided not to put any oil in the engine so it seazed up. does anybody have the firing order for d15b7?
Old Aug 31, 2008 | 03:26 PM
vtecb18c's Avatar
here ya go
https://honda-tech.com/zerothre...03881
Old Aug 31, 2008 | 03:46 PM
one-cam's Avatar
thats not the right firing order mate. my cranks but it wont start now
Old Aug 31, 2008 | 04:01 PM
vtecb18c's Avatar
im pretty sure thats the right order...are you getting fuel?
Old Aug 31, 2008 | 04:54 PM
one-cam's Avatar
yeah i can hear the fuel pump when i turn the key, i checked the fuel return line if theres fuel when i crank the engine and there is
Old Aug 31, 2008 | 05:27 PM
vtecb18c's Avatar
it may be the ignitor in the dizzy......or the coil....theres somethin wrong with the distributor you just have to troubleshoot now...i think the idle fluctuation might have been bad timing all along so i would replace the dizzy or its internals...just my opinion
knavishpear
Jun 19, 2018 11:25 AM
cristegra09
May 13, 2009 06:38 AM
slammedz6ef
Feb 11, 2008 02:47 AM
InvaderTrax
Jul 16, 2007 07:20 PM
geldingmakr
Aug 4, 2004 09:11 AM
