Gsr motor with B16 head Smoking out of every hole?
Old Aug 30, 2008 | 01:31 PM
CCCPRB's Avatar
Default Gsr motor with B16 head Smoking out of every hole?
I just had a motor built its a 91 b16 head with a 94 gsr block it has wiseco low compression and gsr rods and a type-r Crank. i had to motor assembled at a shop and got it back a few days ago so today i finally got it in and hooked up all the wireing and everything else so i go to start it and it starts smokinh out of the breather hole and out of the dipstick kinda scary so im tryinf to figure out what the proble could be or if that part of the begining breakin. please help me figure it out thnx
Old Aug 30, 2008 | 02:05 PM
sohcvtec1995's Avatar
let it warm up and burn off some of the residue.. thats normal.. now if the problem consits then contact the assembler.. .. actully contact him now, so he knows.. the longer you wait the more chances of him saying. :" oh you beat on the motor and didnt break it in correctly its your problem now"
Old Aug 30, 2008 | 04:12 PM
NotNew's Avatar
Default Re: (sohcvtec1995)
ive never seen one do that really, but it does take a little while for the rings to break in, but that should be like 20 minutes. Usually they dont smoke out of the dipstick hole and the breather like that, maybe just a little blow by. Thats kinda weird, maybe he left an oil ring out..
Old Aug 30, 2008 | 09:33 PM
CCCPRB's Avatar
the o ring is in i asked the assembler but the thing that gets me is no signs of a blown head gasket but its got moisture everywhere and the engine runs beautifully like when you get a car out of the dealership lot. i have ran the motor for about and hour and drove it i did not take it past 3700rpms but i feel it has power and no lag so im kinda lost.
Old Aug 31, 2008 | 11:20 PM
CCCPRB's Avatar
any help?
Old Sep 1, 2008 | 12:11 AM
1clean_eg's Avatar
Default Re: (CCCPRB)
I had the same problem with my turbo ls, run like a champ but smoke like a barbecue on wheels. I believed it to be coolant somehow building pressure in the bottem end. I once put my finger over the oil breather and held it there for a couple secs. and when I removed my finger oil escaped like a shaken soda. I really never solved the problem just junked the whole motor and bought another. Sorry I'm no help but I am curious as to what is causing this.
Old Sep 1, 2008 | 08:47 AM
BlackDeuceCoupe's Avatar
HT White Ops
Is you motor oil contaminated with coolant or vise-verse?
If so, I'd say you have a cracked block or the head gasket wasn't installed correctly.
If not, I'd check the entire PCV system for restriction, bad PCV valve, et cetera...
Old Sep 9, 2008 | 06:10 PM
CCCPRB's Avatar
new PCV valve and nothing wrong with oil or coolant
dorado_mike
11
Oct 15, 2010 07:40 PM
88 EF Hatch
Nov 27, 2008 06:45 PM
swapking2
Sep 20, 2007 05:02 PM
bboylito
14
Nov 4, 2004 10:05 AM
notstock93
Nov 14, 2003 05:59 PM
