Cam Plug removal - HELP
Old Aug 30, 2008 | 07:24 AM
AlphaQup's Avatar
Default Cam Plug removal - HELP
Help me out guys. I've tried searching but cant seem to get the right answer. I'm trying to take this plug (#8 as seen in this picture):
Is there a special process to replace this plug? I've already earned a few bloody knuckles tryin to pry this f*cker off. Do I have to take the VC off as well as the Cam holder?
Also, I took my VTEC solonoid off to replace the gasket and found some metal flakes inside the little screen/gasket.... is this something to be concerned about?
Old Aug 30, 2008 | 07:55 AM
Dartanian's Avatar
Default Re: Cam Plug removal - HELP (AlphaQup)
You have to remove the cam cover on the exhaust side and the cap holding the plug down.
Old Aug 30, 2008 | 12:48 PM
AlphaQup's Avatar
Default Re: Cam Plug removal - HELP (Dartanian)
^^ Thanks man!
Old Aug 30, 2008 | 02:51 PM
1992Si's Avatar
Don't worry to much about the metal in the screen. Rinse it out and put it back on.
If you want pull it off again in a few weeks and look for metal. If you see it, then worry.
Chances are it's been there for years.
Old Aug 30, 2008 | 04:55 PM
AlphaQup's Avatar
Default Re: Cam Plug removal - HELP (1992Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1992Si &raquo;</TD></TR><TR><TD CLASS="quote">Don't worry to much about the metal in the screen. Rinse it out and put it back on.
Chances are it's been there for years.</TD></TR></TABLE>
Thanks man! Oh... one more question. Is it safe to use hondabond on the solenoid gasket?
Old Aug 30, 2008 | 09:53 PM
IN VTEC's Avatar
It doesn't need Hondabond. The gasket should be reasonably pliable. If it's hard like plastic, then replace it.
Old Aug 30, 2008 | 10:13 PM
AlphaQup's Avatar
Default Re: Cam Plug removal - HELP (IN VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IN VTEC &raquo;</TD></TR><TR><TD CLASS="quote">It doesn't need Hondabond. The gasket should be reasonably pliable. If it's hard like plastic, then replace it.</TD></TR></TABLE>
Yeah, I was debating on weather or not I should just replace it. The stealer wants freak'n $25 for that little gasket. Oh well, gotta do it the right way. Thanks!
One last question guys, I promise haha. I asked this in a different section with no answers. Are the cam plugs from B16's the same as B18's? Both are VTEC heads.
Modified by AlphaQup at 11:21 PM 8/30/2008
Old Aug 30, 2008 | 10:48 PM
Dartanian's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AlphaQup &raquo;</TD></TR><TR><TD CLASS="quote">Are the cam plugs from B16's the same as B18's? Both are VTEC heads.
Yep, they use the same plugs.
Old Aug 31, 2008 | 12:32 AM
AlphaQup's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dartanian &raquo;</TD></TR><TR><TD CLASS="quote">
Yep, they use the same plugs.</TD></TR></TABLE>
speed84
Sep 6, 2007 06:33 PM
twowords
Jun 21, 2007 05:24 PM
pancake
Feb 10, 2005 01:50 PM
DC2NING
Jun 23, 2004 02:38 PM
boi-alien
Aug 13, 2003 11:01 AM
