b20 vs itr oil pump?
Old Aug 29, 2008 | 08:43 PM
champwhiteEG6's Avatar
Default b20 vs itr oil pump?
So the oil seal on my itr oil pump just went bad and so i today i finally had a chance to replace it. While it was off i compared it to my stock b20 pump lying in my garage and looked at the gears and everything and their the exact same. So whats the deal? How is the itr one better? And I also looked up the pressure for the valve release spring and their the same.
Old Aug 30, 2008 | 03:55 AM
non-VTEC's Avatar
Default Re: b20 vs itr oil pump? (champwhiteEG6)
they are the same.
Old Sep 2, 2008 | 08:24 AM
IanB's Avatar
Default Re: b20 vs itr oil pump? (non-VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by non-VTEC &raquo;</TD></TR><TR><TD CLASS="quote">they are the same.</TD></TR></TABLE>
Vtec vs. non-Vtec oil pumps are not the same, B20 is not vtec so you need the oilpump that matches the head you are using. This link has some really good info as to what the differences are and the consequences of those differences:
http://www.team-integra.net/fo...Topic
Old Sep 2, 2008 | 10:52 AM
fourthgenhatchB17's Avatar
Default Re: b20 vs itr oil pump? (IanB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IanB &raquo;</TD></TR><TR><TD CLASS="quote">
Vtec vs. non-Vtec oil pumps are not the same</TD></TR></TABLE>
I believe the 96+ b series oil pumps are identical. For example, look up the part numbers for a 99 LS and a 99 type r.
Old Sep 2, 2008 | 10:54 AM
doood's Avatar
been there done that
http://www.team-integra.net/fo...Topic</TD></TR></TABLE>
that link you posted said the only difference between the two is a washer
Old Sep 2, 2008 | 10:57 AM
DonF's Avatar
That is so 1994.
Old Sep 2, 2008 | 03:40 PM
IanB's Avatar
Sorry guys, I didn't know it was outdated.
Old Sep 3, 2008 | 05:33 PM
lek9l's Avatar
Default Re: (IanB)
Either will fit, not much of a difference.
Old Mar 31, 2017 | 08:18 AM
solorex's Avatar
I realize this is a REALLY old post. But is a B20 oil pump the same as a P72 (GSR/ITR) pump? Is it really just a washer difference? The pump on my B20b I just had built is fine, just need to know if buying a new ITR pump is warranted. I was planning on porting a new pump.
Old Mar 31, 2017 | 09:26 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
They are the SAME... same part number and everything. There is NO "washer" difference. The confusion lies with the "early" non-vtec pump, found in the '90-95 Integra LS engines... although these pumps appeared similar to the VTEC oil pumps found on the B16A, B17A or B18C1 applications from 1989 to 1995, internally they were different. The shimmed pressure relief valve spring was one of the differences.
Today, only TWO different part numbers are available and the difference is merely the outer casting. If you have a "B" series engine without a crank fluctuation sensor, and thus, the narrow bottomed lower timing belt outer cover, you order the 15100-PR4-A03. If you have a '96+ "B" series application, or you are simply using the "wide" lower timing belt cover (which fits over the crank fluctuation sensor), you use the 15100-P72-A00.
MI4$DC5
Jul 19, 2008 12:16 PM
roycivic92
Aug 30, 2007 02:53 PM
xQB21x
Jan 24, 2007 04:39 AM
showtymers619
Mar 23, 2004 05:49 PM
another_import
Oct 21, 2002 06:30 PM
