DSM injectors
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4drteg54321 »</TD></TR><TR><TD CLASS="quote">will 390cc still flood my motor????</TD></TR></TABLE>
If you're running a stock ecu, anything other than stock will not function properly. You would need some sort of tuning system like hondata/Neptune/Crome etc, to properly control them. But understand this, YOU DO NOT NEED ANYTHING LARGER THAN STOCK INJECTORS FOR YOUR BUILD AT THIS TIME. You will need some sort of tuning system like I mentioned if you want your build to live up to its full potential and be reliable. Understand?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4drteg54321 »</TD></TR><TR><TD CLASS="quote">Will installing DSM 450cc Injectors cause a problem with a Stock ECU with a Ls/Vtec???
Mods:
stock GSR head
Type R piston
B18A1 BLock</TD></TR></TABLE>
YES, stick with stock injectors
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mar778c »</TD></TR><TR><TD CLASS="quote">BTW, hondata does not recommend using them</TD></TR></TABLE>
Would you care to elaborate on this point. I wouldn't mind knowing why they say not too use them other than a 5 year old post.
I would like to know because I have a set of DSM's that I am planning on using. The two rom editors that I have, Crome & eCtune, both have the DSM injectors in there fuel multiplier and battery offset menus. Why would they still have the 450s there if they don't work with the Honda ECU? Or is it just Hondata that can't get them to work?
Mods:
stock GSR head
Type R piston
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GhostAccord »</TD></TR><TR><TD CLASS="quote">
I would like to know because I have a set of DSM's that I am planning on using. The two rom editors that I have, Crome & eCtune, both have the DSM injectors in there fuel multiplier and battery offset menus. Why would they still have the 450s there if they don't work with the Honda ECU? Or is it just Hondata that can't get them to work?</TD></TR></TABLE>
The link is hondata specific.
http://www.hondata.net/forum/viewtopic.php?t=432
But that is not the 1st time, I've heard a reputable source dislike DSM injectors.
But that is not the 1st time, I've heard a reputable source dislike DSM injectors.</TD></TR></TABLE>
Yes I read that very short and blunt (no tech data) thread. It talks about Honda ECU's in general. Not just Hondata related. It's 5 years old though. Is there anything recent that anyone can post up? Isn't that why there are battery offsets in some of the newer ROM editors? Any tuners have some input here. I'm not a big follower of heresay.
The only way to know is to determine the characteristic curves of the DSM injectors and compare them to honda injectors. The only people I could think of who know this information would be rc engineering.
frostcivic
Aug 6, 2004 02:22 PM
Diego Boost
Feb 26, 2003 11:10 AM
