car wont start, solid CEL light, replaced ecu already!
Old Aug 28, 2008 | 07:26 PM
K i l l a B e e.'s Avatar
Default car wont start, solid CEL light, replaced ecu already!
my car wont start, im getting a spark too. Yesterday i went to pick up my gf, and before she got in the car, i bent over to the passenger side to put my ecu back into the corner so that she wouldnt kick it with her feet. When i picked it up, i saw a spark and the car shut off. I thought i burnt out the ecu so i bought another one, but my car still wont start. Is there a fuse for the ecu?
the car is a 96 honda civic hatchback, used to be automatic, now it's converted to manual running a jdm b18c R
Old Aug 28, 2008 | 07:27 PM
Hanmin's Avatar
check the fuses... all the fuses. the ecu one is under the dash, in eg's anyways, not sure about eks.
Old Aug 28, 2008 | 08:32 PM
Default Re: (Hanmin)
i dont seee an ecu one. i just checked the main relay, tht fine.
Old Aug 28, 2008 | 09:08 PM
Default Re: car wont start, solid CEL light, replaced ecu already! (K i l l a B e e.)
where is the ecu fuse fr a 96-00? there is nothing labled ECU in the engine bay or driver side dash.
Old Aug 28, 2008 | 10:32 PM
user 98292739's Avatar
should be in the bay mine is. it snot labeled ECU if i remembered correctly it was labedl something else.
Old Aug 29, 2008 | 12:41 PM
Hanmin's Avatar
just check all of your fuses...
Old Aug 30, 2008 | 04:42 PM
integrals21's Avatar
are you getting fuel? listen for it if you don't hear i bet your fuel fuse is busted....
Old Aug 30, 2008 | 07:54 PM
Historyg's Avatar
fuel fuse? he said he checked the main relay, i dont understand. is their such a thing as a fuel fuse...
anyways to the op, it has to be a fuse check everything it sounds annoying, but you will eventually find it, i dont think you burnt out the ecu, just caused a short. since you bought a new one might as well not worry about it now.
Old Aug 30, 2008 | 10:07 PM
Default Re: (Historyg)
yeah you guys were right. it was a fuse. my first response when the car didnt turn on was check the fuse, but i didnt see a fuse called "ecu" so i skipped that... i couldve saved 6hrs of driving and 80$ for a new ecu if i wouldve checked ALL the fuses.
Old Aug 31, 2008 | 06:54 PM
yes there is such thing...don't remember the exact term but there is one..it controls the fuel....
thats good you got it fix
Old Aug 31, 2008 | 08:48 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
Default Re: (K i l l a B e e.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by K i l l a B e e. &raquo;</TD></TR><TR><TD CLASS="quote">yeah you guys were right. it was a fuse. my first response when the car didnt turn on was check the fuse, but i didnt see a fuse called "ecu" so i skipped that... i couldve saved 6hrs of driving and 80$ for a new ecu if i wouldve checked ALL the fuses. </TD></TR></TABLE>
always check your fuses first. that's the purpose of them to stop the circuit in it's tracks.
Old Sep 1, 2008 | 01:08 AM
Default Re: (HybridcivicLS-T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HybridcivicLS-T &raquo;</TD></TR><TR><TD CLASS="quote">
always check your fuses first. that's the purpose of them to stop the circuit in it's tracks. </TD></TR></TABLE>
yeah , i've never had this problem before on my ek. on my eg, i knew there was a fuse called "ECU" but on the EK it's named something else, thats why i didnt bother checking all the fuses. Oh well, you live and learn . thanks HT
Vtec04
Honda Civic (2001 - 2005)
Oct 3, 2016 06:41 PM
EdSales
Mar 23, 2010 09:41 AM
001020
11
Sep 7, 2005 07:44 AM
poundedhatchcrap
Aug 25, 2005 02:29 PM
