HELP!!! no oil in h22
Old Aug 28, 2008 | 03:08 PM
Varano44's Avatar
Default HELP!!! no oil in h22
I need some serious help I just tried to start my freshly built h22 and it's not getting oil.
Old Aug 28, 2008 | 04:21 PM
Varano44's Avatar
Default Re: HELP!!! no oil in h22 (Varano44)
Anybody know the amount of cranks it takes to prime the oil pump on a fresh build?
Old Aug 28, 2008 | 04:38 PM
Acidcrakker's Avatar
lemme state the obvious.
Have you checked to see the oil pump is clogged?
Old Aug 28, 2008 | 04:41 PM
Varano44's Avatar
Default Re: HELP!!! no oil in h22 (Acidcrakker)
how can I check
Old Aug 28, 2008 | 04:45 PM
First off how do you know your pump isnt working? Are you getting an oil light?
Second is the whole motor new parts or old parts?
Who did the build?
Old Aug 28, 2008 | 04:48 PM
Varano44's Avatar
XES did the build, and im not sure if they are new parts or not im assuming they are used, I have an oil pressure gauge and my oil feed to my turbo is dry.
Old Aug 28, 2008 | 04:57 PM
So than your Turbo isnt getting any oil.
If you have no oil pressure, well that cant be good.
Id call said builder and let them know whats going on.
Hopefully your just not using the oil pressure gauge right.
You can however, if your feeling really spirited, pull the oil pan off and check the oil feed tube inside the motor.
Old Aug 28, 2008 | 05:11 PM
Varano44's Avatar
Yeah i sent him a pm, and i know the oil pressure gauge is working because thats been on my car and the oil feed line is off the same tap, and the oil feed is off of my other h22 that worked so i can really only be the oil pump i think.
xlasianizelx
Aug 10, 2010 02:28 PM
Varano44
53
Sep 5, 2008 10:28 PM
crxsiperf
Nov 23, 2005 04:36 PM
dominate9
Dec 15, 2004 05:51 PM
B18Flip
Apr 17, 2004 05:15 PM
