Stuck Axle Nut on a Honda Del Sol '93
Old Aug 28, 2008 | 08:10 AM
jh08558's Avatar
Default Stuck Axle Nut on a Honda Del Sol '93
The Front Driver side axle nut is frozen. I've even tried a 3 foot cheater bar when trying to loosen it. Is there something I'm missing? Any suggestions?
Old Aug 28, 2008 | 09:39 AM
jdmdikk's Avatar
Default Re: Stuck Axle Nut on a Honda Del Sol '93 (jh08558)
in had the same problem on my ek with that dam axle nut..what i did was that i cut the nut off the top but then again i did not need my axle..you could use a drill bit or a dremel with a metal cutting piece..
Old Aug 28, 2008 | 09:43 AM
messeduprex's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jh08558 &raquo;</TD></TR><TR><TD CLASS="quote">The Front Driver side axle nut is frozen. I've even tried a 3 foot cheater bar when trying to loosen it. Is there something I'm missing? Any suggestions?</TD></TR></TABLE>
did you de-stake the nut?
Old Aug 28, 2008 | 09:49 AM
bTwink's Avatar
Default Re: Stuck Axle Nut on a Honda Del Sol '93 (messeduprex)
if a 3ft. cheeter bar dont work use AIR
my buddie broke like 4 breaker bars on an axle nut, we brought over an impact and had no problem
Old Aug 28, 2008 | 10:27 AM
Pothole987's Avatar
did you unbend the notch? i've had problems with them too, and i used a impact off an 8gal 7hp(?) compressor.
i ended up using a torch to heat it up, then using a 3/4inch breaker bar with another 3 foot pole on that.
it was a f**king *****.
Old Aug 28, 2008 | 10:42 AM
Default Re: Stuck Axle Nut on a Honda Del Sol '93 (Pothole987)
i personally just stand on the breaker bar and bounce up and down on it. and always lossen the axle nut with the tires on and on the ground
Old Aug 28, 2008 | 11:05 AM
RagnarX's Avatar
i weigh 200 pounds and bouncing up and down on it didn't even budge. Gave up and bought a impact gun and compressor, came of eeeaasssy
Old Aug 28, 2008 | 11:28 AM
mr4dr.'s Avatar
i had to use a 10ft fence post.. but it did the trick!
Old Aug 28, 2008 | 11:42 AM
vanste's Avatar
see if the tab is bend in if so un-bend it and try it, if no luck torch that nut and try again...
slvrcvc93's Avatar
Default Re: Stuck Axle Nut on a Honda Del Sol '93 (mr4dr.)
make sure you put anti seize on that bad boy so it doesn't happen again
Old Aug 28, 2008 | 01:41 PM
BlueIntegraBoy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by messeduprex &raquo;</TD></TR><TR><TD CLASS="quote">i personally just stand on the breaker bar and bounce up and down on it. and always lossen the axle nut with the tires on and on the ground</TD></TR></TABLE>
LOL, I did this with a 4 ft extension on my friend's car. Snapped the drive on the breaker bar.
Old Aug 30, 2008 | 05:28 AM
jdmdikk's Avatar
Default Re: Stuck Axle Nut on a Honda Del Sol '93 (BlueIntegraBoy)
i snapped 2 or 3 breaker bars on my ek..lol..just cut the nut if you dont need or heat it up..
Old Aug 30, 2008 | 03:26 PM
B18C1EM1's Avatar
Default Re: Stuck Axle Nut on a Honda Del Sol '93 (jdmdikk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmdikk &raquo;</TD></TR><TR><TD CLASS="quote">i snapped 2 or 3 breaker bars on my ek..lol..just cut the nut if you dont need or heat it up.. </TD></TR></TABLE>
Just buy a quality air gun and you dont have these dumb problems
jvaughn
18
May 27, 2009 10:24 AM
w0ng_sta
Dec 22, 2006 10:06 AM
JJ's civic
13
Oct 22, 2006 03:42 PM
B17CRXracer
34
Jun 19, 2005 11:13 PM
gsrcivic619
10
Jan 5, 2004 04:07 PM
