caliper or the master cylinder?
Old Jul 24, 2002 | 06:58 AM
slick11227's Avatar
Default caliper or the master cylinder?
Front driver side brake feels as if it is stuck.. I changed the pads.. did no good... Caliper acts as if its stuck on pad.. but the brake pedal is very sift.. as if theres air in lines or master cylinder went out.. any possibilities ? or anyone HAD SIMILAR PROBLEMS????
PLEASE HELP....
IM GETTING DESPERATE
Old Jul 24, 2002 | 07:01 AM
Brandon's Avatar
Life is Suffering
Default Re: caliper or the master cylinder? (slick11227)
You need to get the caliper rebuilt or replaced. That is because something in the caliper, most likely the piston, is frozen.
Old Jul 24, 2002 | 07:14 AM
slick11227's Avatar
Default Re: caliper or the master cylinder? (accordvtec)
thank you majn.. this doesnt sound liek the master cylinder to you though ? beeing that the pedal ( brake pedal) is very soft and airy ???
Old Jul 24, 2002 | 07:23 AM
YeuEmMaiMai's Avatar
sounds like you have 2 problems
1. frozen caliper
2. air in your lines
you can bleed them in the following order
any front wheel, opposite rear wheel, other front wheel, remaining rear wheel
Old Jul 24, 2002 | 07:26 AM
Brandon's Avatar
Life is Suffering
I forgot to recommend one thing first. You need to do two things, flush the brake fluid and replace with Valavoline Syntec DOT 3/4 brake fluid and bleed the brakes properly. If that doesn't work, then replace the master cylinder. I acidentally missed the part about brake pedal feel .
TWG's Avatar
TWG
Default Re: caliper or the master cylinder? (YeuEmMaiMai)
Is that the proper bleed order ?
My Haynes manual recommends front left, front right, rear right, and rear left...
Old Jul 24, 2002 | 07:40 AM
John's Avatar
New User
Default Re: caliper or the master cylinder? (TWG)
Bleeding order:
Rear right, front left, rear left, front right.
Old Jul 24, 2002 | 08:14 AM
slick11227's Avatar
Default Know of any good place to find cheap rebuilt/new front driver side caliper?
Know of any good place to find cheap rebuilt/new front driver side caliper?anything online with quick delivery ?
Old Jul 24, 2002 | 10:48 AM
greensleeper's Avatar
Default Re: Know of any good place to find cheap rebuilt/new front driver side caliper? (slick11227)
this is the third time I have posted phone numbers for salvages yards for people to find used calipers in two days. I should just put it in my sig.
Woodfins - 800-223-4663
Olstens - 402-467-4541
Old Jul 24, 2002 | 11:29 AM
4doorH22's Avatar
On every frozen caliper I've seen you could not change the pads because you couldn't compress the piston far enough to fit the new pads over the rotor! So if you put on new pads and were able to compress the piston it's probably isn't seized. With the car in the air does that wheel spin with particularly high resistance?
Stanceman
Dec 28, 2017 05:41 AM
5rivers
Oct 10, 2015 06:44 AM
ribal_gh
11
Apr 30, 2013 04:24 AM
EGh22please
Apr 30, 2011 12:34 PM
ice11honda
Feb 24, 2005 12:56 PM
