Sensor Broken
Old Aug 26, 2008 | 03:40 PM
TigerLy's Avatar
Default Sensor Broken
Okay so as i was looking around the motor a few days ago i noticed that one of my sensors what cracked so i just touched it and it broken and then i started my car and the check engine light comes on so then i turn off the car and push the sensor together and then the check engine light turns off.. and now it comes back on once in awhile.. and i went to acura to find out what kind of sensor that was and they wanted me to pay them just to look at it so they can tell me what sensor it is.. well the sensor is located under the distrubtor and it's connected to the head.. there is a big one and a small one.. i need to know what the big one is..
Old Aug 26, 2008 | 04:09 PM
shanehate's Avatar
Default Re: Sensor Broken (TigerLy)
post a picture if you can
Old Aug 26, 2008 | 04:35 PM
BoSox46GSr's Avatar
Default Re: Sensor Broken (shanehate)
Post a pic if you can, but it sounds like it might be the temp sensor. You notice the temp gauge acting strange?
Old Aug 26, 2008 | 05:10 PM
TigerLy's Avatar
Default Re: Sensor Broken (BoSox46GSr)
no it does not act strange.. it works just fine..
Old Aug 26, 2008 | 05:16 PM
TigerLy's Avatar
here are the pictures.. if you want to see it from any other angle just let me know..
Old Aug 26, 2008 | 09:42 PM
doughboixx's Avatar
HEy bro.
i had the same problem happen to me last year...
that sensoris the engine coolent temp sensor i believe...
that sensor is easy to find. just go to any pick and pull, wrecking hard or if your buddies have any motor laying around from singles to h22s and all the b series motors...there all the same thing...and with that broken i think yoru ilde should be high too if im correct....
i hope this helps...
http://www.autodynamics-honda.....html
or you can buy that brand new....
Old Aug 28, 2008 | 12:30 PM
TigerLy's Avatar
Default Re: Sensor Broken (doughboixx)
alright thanks i'll look into that coolant temp.. but my car used to idle high and weird like it would go up and down constantly but then i adjusted my timing and it's back down to 700-800 rpm now..
Old Aug 28, 2008 | 08:31 PM
doughboixx's Avatar
yeah the idle does do that...it jumps up and down...
once you fix it your idle should be perfect liek before...
c0d0r
May 5, 2009 01:07 PM
99d-series
May 1, 2009 08:56 AM
HATCHFREEK
Mar 19, 2003 10:32 AM
