HELP!! stripped bolt!!
Old Aug 26, 2008 | 12:48 PM
allmotadb8's Avatar
Default HELP!! stripped bolt!!
stripped the threading on bolt #24.. how would i go about rethreading it? or do i need to just replace it? Thanks in advance.
Old Aug 26, 2008 | 01:41 PM
philafelman's Avatar
Default Re: HELP!! stripped bolt!! (allmotadb8)
you can just replace the stud, or see if you can go over it with a rethreader or tap/dye kit and see if you can get the threads good again. i believe its 12 x 1.25 thread.
Old Aug 26, 2008 | 10:19 PM
cjo_28's Avatar
You need to replace the stud. Sometimes those studs freeze in the transmission case. Good luck.
Old Aug 26, 2008 | 10:43 PM
HaulingAddison's Avatar
if all else fails, retap the hole a little bit bigger, and put a heli-coil in it with some lock tite. (That's worst case, try the other ideas first). Make sure when you do that though that the thred pitch is the same.
Old Aug 27, 2008 | 08:40 AM
EFbomb's Avatar
I'd replace, its cheap.
An idea for getting it out
1. Heat up the tranny thread area with torch, its aluminum and should expand easily/faster than the stud. Try using vice-grip pliers to take the stud out of the tranny.
Or if there is any decent thread left at the top of that stud, i've taken 2 nuts back to back and locked them together, then use the bottom one to try to back the stud out.
good luck
Old Aug 27, 2008 | 09:39 AM
ED9man's Avatar
i'd be careful heating that area, you could melt the plastic oil guide plate inside the transmission
Old Aug 27, 2008 | 11:49 AM
allmotadb8's Avatar
the biggest problem for me is removing the bolt. i might try what efbomb suggested but id like to hear some more advice. my motor is already in the chassis so putting a vice grip on that bolt is kinda hard. u can do it but when u need the leverage to turn the dam thing ur arms in an awkward position. any more advice will be kindly appreciated !
Old Aug 27, 2008 | 03:20 PM
1992Si's Avatar
How much HP you making?
Under 350. I wouldn't worry about it as long as the other mounts are good. Next time the tranny's out fix it then.
Old Aug 27, 2008 | 03:38 PM
allmotadb8's Avatar
im pretty sure im not making 350 hp. is a stock gsr short block with a b16 head all stock. are you sure im ok without it? seems abit dangerous to me
Old Aug 27, 2008 | 03:47 PM
1992Si's Avatar
PM'd you back.
One of our crew has a 95 Teg with 325whp and he has the same stud issue, he runs the car with slicks and hasn't had a issues. Just make sure all the other mounts are good.
Do you have the manual yet?
http://hondatech.info/downloads/Auto/Manuals/
Modified by 1992Si at 9:50 PM 8/27/2008
Old Aug 27, 2008 | 06:01 PM
loco_rides's Avatar
Go to your local tool shop and get a stud exstactor the retail for like $20 and up pop it on there and spin it out then replace it with a new one... very easy fix.
Old Aug 28, 2008 | 02:43 AM
1992Si's Avatar
Default Re: HELP!! stripped bolt!! (loco_rides)
Yea, I didn't think of that. Got one laying around the house somewhere. I should put it in the tool box in the trailer.
Remember to spray it with PB Blaster first.
Old Aug 29, 2008 | 09:46 AM
happycorey's Avatar
Default Re: HELP!! stripped bolt!! (1992Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1992Si &raquo;</TD></TR><TR><TD CLASS="quote">Remember to spray it with PB Blaster first.</TD></TR></TABLE>
Do that if you're going to attempt to get it out, otherwise, there's two other bolts that hold that tranny mount on, and it should be okay.
95_Civic_4dr
Transmission & Drivetrain
Sep 18, 2009 07:10 AM
itzyaboyzeem03
Aug 24, 2008 04:37 PM
kyorishin
Apr 11, 2006 11:02 PM
94DOHCDELSOL
Jan 29, 2005 07:03 PM
