please help!!!!!!
please help!!!!!!
i was trying to add tranny fluid to my tranny but i accidentally used the wrong wrench and ended up stripping the filler bolt!!! i tried to use a wrench but it keeps stripping it....how can i get the bolt off?? im about to go to autozone real quick and buy me another bolt....but i need to fill up the tranny today, it has a leak and i can tell by how hard it is to put it in gear that the fluid level is low
Re: please help!!!!!! (thizboii)
get the striped bolt kit irvan's i think its called and a new bolt before u try to put it in. Or u could take it to a quick lube in the morning they will know what to do.
Re: please help!!!!!! (just_hatched)
try taking a 12 point wrench 1 size sma;ller than the original bolt size and hammer it onto the bolt thats what i do at work when i run into stripped oil drain plugs or get the stripped bolt kit as just hatched had mentioned
Re: please help!!!!!! (Unit44justin)
heres an update.........I [freak]ED UP....well i decided to just take off the vss and fill the tranny that way....so i did....then when i tried to put the mechanical piece in, it kinda go stuck, so i forced it in, and it wouldnt go in all the way...i tried to take it out but it wouldnt come out...so i got a lil hammer and tried to hit it in, and it started going in slanted....i messed with it for about 30 mins....until i gave up and screwed the top part onto it and left it like that....ill get a new one 2morro but how am i going to get the old one out??
asubennett
08-21-2003 05:14 PM
RCautoworks
02-16-2003 11:16 PM
