Water In Oil, Newly Built Block, Never been Ran
Old Aug 25, 2008 | 06:47 AM
dmotoguy's Avatar
Default Water In Oil, Newly Built Block, Never been Ran
b18c, 81.5 cps/eagle rods, fresh head..
I was filling my new motor up with water/oil getting ready to start it for the first time last night. I heard a gurgling in my catch can when I was adding the water. I then saw water leaking from my turbo drain bung on the oil pan..
Is there a plug somewhere inside that would allow this to happen? where should I start looking?!
Old Aug 25, 2008 | 07:45 AM
1992Si's Avatar
Default Re: Water In Oil, Newly Built Block, Never been Ran (dmotoguy)
Is the block sleeved?
I'll assume there is a head gasket installed...
Old Aug 25, 2008 | 08:04 AM
dmotoguy's Avatar
Default Re: Water In Oil, Newly Built Block, Never been Ran (1992Si)
stock sleeves...
head gasket is there (oem)
Old Aug 25, 2008 | 11:39 AM
KooK's Avatar
Mustang Sally
How in Gods name... In for the results because that's gotta be a big leak.
Did you have any head work done at all? Have you used this head before?
Old Aug 25, 2008 | 12:23 PM
dmotoguy's Avatar
Default Re: Water In Oil, Newly Built Block, Never been Ran (KooK)
I did, the machine shop hot tanked it, then did a valve job..
Old Aug 25, 2008 | 01:16 PM
King V's Avatar
Last I've heard, you never hot tank anything aluminum.
Old Aug 25, 2008 | 01:31 PM
dmotoguy's Avatar
Default Re: Water In Oil, Newly Built Block, Never been Ran (King V)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by King V &raquo;</TD></TR><TR><TD CLASS="quote">Last I've heard, you never hot tank anything aluminum.</TD></TR></TABLE>
I'm not sure if they "hot-tanked" it like a steel block... im pretty sure they just dissassembled it and cleaned it in the parts cleaner...
Old Aug 26, 2008 | 02:50 PM
91h22cb7lx's Avatar
ive never seen a hot tank that got hot enough to warp a head, maybe because the head wasnt bolted down it would be easier
Old Aug 28, 2008 | 06:45 AM
dmotoguy's Avatar
Default Re: Water In Oil, Newly Built Block, Never been Ran (91h22cb7lx)
**Problem Solved**
I hooked up a water line to the little nipple for the catch can.... pumping water into your crank case FTL!
I ran 16 quarts of oil through the motor last night.. hopefully that flushed all the water out pretty good... once I get my car running I'll probably change the oil in 50-100 miles.
Old Aug 28, 2008 | 01:43 PM
DonF's Avatar
Standard installer error. Glad you found it. 2nd time i have heard of this.
andypwnz
Feb 19, 2013 03:40 PM
EK4Vti
Nov 12, 2008 08:50 AM
2wheelhunter
11
Mar 9, 2008 10:31 PM
caminSi
Jul 27, 2006 07:52 AM
DrkGreenAccord
Jul 10, 2005 01:06 AM
