Southern California Fresno & Below
new to this CA swap stuff..help?
Old Aug 24, 2008 | 07:45 PM
mojackson2390's Avatar
Default new to this CA swap stuff..help?
so i just bought my 96' civic and it has a b16a swap, if i dont have the "papers" for this swap saying that the car it came out of isnt stolen is there any way i can get them? basicall i want this to be all legal...
Old Aug 24, 2008 | 11:50 PM
Radim's Avatar
Default Re: new to this CA swap stuff..help? (mojackson2390)
Can't legalize it right now anyways, Dumbass Arnold hit the DMV with budget cuts, BAR stations are out of commission for a bit. But you should be able to smog it since it's 1.6liter....Dude who smogs my car said it's cool as long as it's not bigger than the biggest engine they have for your model. This is at a test only station mind you.
Old Aug 25, 2008 | 12:20 AM
Default Re: new to this CA swap stuff..help? (Radim)
1) is there anyway i can find out if it is stolen at least?
2) what happens if i dont have carb stickers?
3) if the cop sees that my engine is made in 2000 (the produced date on the block) cant he ask me for papers on my swap?
Modified by mojackson2390 at 1:26 AM 8/25/2008
Old Aug 25, 2008 | 02:08 PM
Radim's Avatar
1, Not sure
2. Modification Ticket or Ref ticket.
3. They don't know crap here, if they do Ref Ticket...
Since the DMV Budget Cuts, there isn't a ref station either so you can contest the ticket... or so somebody said on EF Forums.
Old Aug 25, 2008 | 03:31 PM
Ldo's Avatar
Ldo
What's the engine block code on your B16? is there a number following B16? If not, it's a JDM engine and you can't really trace the history of those.
If it's a USDM motor, the CHP can trace the serial number.
If you don't have aftermarket parts, chances are they won't know what they're looking at.
Old Aug 25, 2008 | 04:33 PM
Default Re: new to this CA swap stuff..help? (Ldo)
it just says b16A....???
and i have headers and a cold air intake.
Old Aug 25, 2008 | 09:33 PM
Ldo's Avatar
Ldo
Get the CARB legal header and intake from a 94 Del Sol DOHC Vtec or DOHC Vtec Si. DC and AEM both have CARB EO #'s for them. With those, at least they won't look further when they pull you over. Most cops can't even tell what year the motor is. Cheap intake & headers without CARB EO numbers will get you in trouble.
Your motor being a JDM, they can't trace it. Except if it was stolen and the previous owner reported its serial number to the CHP.
Old Aug 25, 2008 | 11:22 PM
o ok...well is there a paper that i need to get saying that it is not a stolen motor? u know...like turn in the cereal # to the CHP and get it checked?
Old Aug 26, 2008 | 03:44 PM
Radim's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mojackson2390 &raquo;</TD></TR><TR><TD CLASS="quote">o ok...well is there a paper that i need to get saying that it is not a stolen motor? u know...like turn in the cereal # to the CHP and get it checked? </TD></TR></TABLE>
Just leave it alone, you can't BAR it so it doesn't matter.
Run it how it is, and wait untill BAR stations open back up.
You can probably take the serial to the CHP and get it run through the system.
Old Aug 26, 2008 | 06:19 PM
Ldo's Avatar
Ldo
As a precaution, if you're gonna ask the CHP to run the serial number, just tell them that you are about to buy a motor with such and such serial number and that you want to verify its legal status before buying. If it is a hot motor, at least they won't hold you for questioning.
Old Aug 27, 2008 | 11:56 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ldo &raquo;</TD></TR><TR><TD CLASS="quote">As a precaution, if you're gonna ask the CHP to run the serial number, just tell them that you are about to buy a motor with such and such serial number and that you want to verify its legal status before buying. If it is a hot motor, at least they won't hold you for questioning. </TD></TR></TABLE> alright..thanks. kina sounds like they got u
kaison
19
Jun 12, 2013 12:21 AM
Honda97
Oct 12, 2004 07:44 AM
wuclan
Feb 7, 2004 04:54 PM
black-hatch
Feb 10, 2003 04:52 AM
2.2
Aug 21, 2001 11:24 PM
