check engine light
Old Aug 24, 2008 | 06:37 PM
Hondacrxblk's Avatar
Default check engine light
The light comes on and off, i suspect the 02 sensor, also the car was in an accident and know the ac dosent work. i checked the fuse and it was blown, replaced it and then it blew again. ideas?
Old Aug 24, 2008 | 06:41 PM
Syndacate's Avatar
Default Re: check engine light (Hondacrxblk)
Tell us WHICH check engine light. That could help readers diagnose the problem better.
You shouldn't "suspect it's the O2 sensor" just because it's a check engine light. The CEL has MORE than one function. If it didn't, it'd be called the O2 sensor light.
If you have a '96+ year car, you can get the car scanned for free at autozone, pep boys, advance auto, or the like - they can tell you what CEL's it's throwing.
If you don't want to leave your house or have a pre '96 civic, go here:
https://honda-tech.com/zerothread/1901557
The OBD-I codes you get from that link aren't as accurate as the OBD-II codes you can get from an OBD-II scan tool if your car is '96+, but they can give a pretty good idea as to what the problem is.
Old Aug 24, 2008 | 06:43 PM
oh, im reading up on that now.
Old Aug 25, 2008 | 10:36 AM
NOFX's Avatar
H-T White Ops
Just go to Autozone or another parts store and ask if they'll check your car for codes. They'll go out there and plug a scanner into a socket under the dash and it will read whatever codes your car is throwing. Autozone can then print out the code and most likely causes for that code.
It's all free.
campbellr85
May 11, 2017 03:32 PM
Vcastro
Mar 8, 2007 04:57 AM
jeffro d
May 19, 2004 03:23 AM
DC2ITR
Apr 2, 2002 06:57 AM
