Oil and Oil Filter
Old Aug 23, 2008 | 01:41 PM
waken's Avatar
Default Oil and Oil Filter
I recently bought a 95 Integra with a 2000 spec B18C engine swap. I need to change the oil, but I am unsure about what oil filter and oil to use. One person has told me that I should run a Honda s2000 oil filter. I would prefer to use a stock oil filter, but I would also prefer not to buy one from Acura since they charge a lot.
As far as oil goes I al leaning towards 5W-30 full synthetic Mobile 1. Can someone pleas help?
Old Aug 23, 2008 | 01:47 PM
RTW DC2R's Avatar
Default Re: Oil and Oil Filter (waken)
I use fram filters and pennzoil 10w30 in my stock R motor, and my turbo R motor. :shrugs:
Old Aug 23, 2008 | 01:58 PM
get RIGHT's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by waken &raquo;</TD></TR><TR><TD CLASS="quote"> I would prefer to use a stock oil filter, but I would also prefer not to buy one from Acura since they charge a lot.
You can use a stock filter if you like and your oil chioce is fine.
Old Aug 23, 2008 | 02:24 PM
Haleiwa-Brando's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by waken &raquo;</TD></TR><TR><TD CLASS="quote">I recently bought a 95 Integra with a 2000 spec B18C engine swap. I need to change the oil, but I am unsure about what oil filter and oil to use. One person has told me that I should run a Honda s2000 oil filter. I would prefer to use a stock oil filter, but I would also prefer not to buy one from Acura since they charge a lot.
The reason why they recommended the S2000 filters (which I used) is that it's OEM quality, works, and keeps oil pressure up. Personally, I went a step further and put a hose clamp around the oil filter to keep it from swelling and expanding.
Old Aug 23, 2008 | 02:38 PM
get RIGHT's Avatar
Default Re: Oil and Oil Filter (Haleiwa-Brando)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Haleiwa-Brando &raquo;</TD></TR><TR><TD CLASS="quote">
The reason why they recommended the S2000 filters (which I used) is that it's OEM quality, works, and keeps oil pressure up. Personally, I went a step further and put a hose clamp around the oil filter to keep it from swelling and expanding.</TD></TR></TABLE>
I ditto this assesment for my personal as well. Even down to the band.
Old Aug 23, 2008 | 02:42 PM
IntegraType-R's Avatar
Default Re: Oil and Oil Filter (RTW DC2R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTW DC2R &raquo;</TD></TR><TR><TD CLASS="quote">I use fram filters and pennzoil 10w30 in my stock R motor, and my turbo R motor. :shrugs:</TD></TR></TABLE>
conven oil in an itr.. i laughed alittle bit.
Old Aug 23, 2008 | 03:01 PM
mikestypeRR's Avatar
Default Re: Oil and Oil Filter (IntegraType-R)
Use the s2000 oil filter.. the filter is slightly smaller than the ITR filter, causing a slightly better oil pressure, you will feel a smoother "not as noticable Vtec cross over" which anyone who knows that equates to less of the infamous power loss "dipp" in the vtec cross over portion on a dyno chart.
The mad vtec boom is just cool sounding, if you want performance do it right.
Do you self a favor and use synthetic oil, Ive used both mobile 1 20-30w and castrol GTX 20-30 ... I noticed the mobile 1 had more of a tendency to burn causing a higher oil consumption rate vs. the castrol... anyone else notice this?? chime in I am sure it wasnt my imagination.
Old Aug 23, 2008 | 05:18 PM
Default Re: Oil and Oil Filter (mikestypeRR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mikestypeRR &raquo;</TD></TR><TR><TD CLASS="quote">Use the s2000 oil filter.. the filter is slightly smaller than the ITR filter, causing a slightly better oil pressure, you will feel a smoother "not as noticable Vtec cross over" which anyone who knows that equates to less of the infamous power loss "dipp" in the vtec cross over portion on a dyno chart.
Do you self a favor and use synthetic oil, Ive used both mobile 1 20-30w and castrol GTX 20-30 ... I noticed the mobile 1 had more of a tendency to burn causing a higher oil consumption rate vs. the castrol... anyone else notice this?? chime in I am sure it wasnt my imagination.</TD></TR></TABLE>
I had the same problem
Went over to 0w-40 and the problem is gone.
Old Aug 23, 2008 | 05:31 PM
RTW DC2R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntegraType-R &raquo;</TD></TR><TR><TD CLASS="quote">
conven oil in an itr.. i laughed alittle bit.</TD></TR></TABLE>
why? i beat the **** out of both cars and have no engine problems. neither cars consume oil. oil temps and pressure is controlled. and i change it frequently so there is no problem
Old Aug 23, 2008 | 05:36 PM
why? i beat the **** out of both cars and have no engine problems. neither cars consume oil. oil temps and pressure is controlled. and i change it frequently so there is no problem </TD></TR></TABLE>
There's a reason syn oil is better then conven....To each his own.
Old Aug 24, 2008 | 08:36 AM
coolhandluke's Avatar
There's a reason syn oil is better then conven....To each his own. </TD></TR></TABLE>
You have a point, and i agree. However, your method of pushing your point is not effective. Synthetic is definitely superior for its start up tendencies alone. The higher cost($13 for Conv, $23+ Syn) and sometimes limited availability(depends on oil choice) is its main downfalls.
Old Aug 24, 2008 | 09:50 AM
ITRBOY1433's Avatar
i didnt know about using the s2k oil filters!
Old Aug 24, 2008 | 10:25 AM
Devon M's Avatar
Default Re: (ITRBOY1433)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITRBOY1433 &raquo;</TD></TR><TR><TD CLASS="quote">i didnt know about using the s2k oil filters!</TD></TR></TABLE>
Me either, I always bought the K&N arm and a leg filters. Then when I bought my R the previous owner Smalltownva turned me onto them. Once I got home I did some research and now I don't buy K&N anymore.
Old Aug 24, 2008 | 11:37 AM
Toe_Knee's Avatar
Pics of the clamp on the filter? I've never heard of this.
Old Aug 24, 2008 | 11:52 AM
Default Re: Oil and Oil Filter (Toe_Knee)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Toe_Knee &raquo;</TD></TR><TR><TD CLASS="quote">Pics of the clamp on the filter? I've never heard of this.</TD></TR></TABLE>
I don't have any off hand. It is simple though.
1) Take a S2000 oil filter in your right hand.
2) Take a hose clamp of a slightly larger O.D. in your left hand.
3) Slide hose clamp over the oil filter.
4) Tighten down firm over the middle area of the oil filter (middle of oil filter length).
5) Put on R.
6) Profit.
Old Aug 24, 2008 | 12:40 PM
Toe_Knee's Avatar
Sounds easy enough, thanks.
happynoodleboy
Feb 20, 2008 06:34 PM
o0oz
Feb 20, 2007 04:54 PM
Blazin Civic
55
Jul 11, 2004 07:01 PM
dclub01
May 1, 2003 03:22 PM
