c.v. shaft problem
hey i have usdm 32mm hubs and i need to install a jdm itr motor. how do i get the shafts to work with my usdm hub?
also the only way to differ a lsd trannie is to take out the trannie from the block? or can i look through where the shafts go in? the "LSD" stamp isnt on the trannie...
Use regular Integra axles?
Look through the tranny with the axles removed. If you can see straight through you've got LSD. If there's a bar in the middle, sorry, no LSD
i dont think you can use regular usdm b series axles, reason being is because the jdm itr trannies came with 36 spline axles..someone please correct me if i can just use ordinary usdm b series axles and if the inners will fit into the jdm trannie..thank you
BowDownCRX31
Sep 19, 2011 09:15 AM
