97 SS with 112k....change or not to change the tranny oil?
Old Aug 21, 2008 | 07:36 PM
integraboi1010's Avatar
Default 97 SS with 112k....change or not to change the tranny oil?
I have been getting mix results regarding whether to drain my tranny fluid and replace them with 3 new qts from Honda.
Car have 112k right now, it shift OK right now.
I'll be doing alot of highway driving.....for commuting...240miles each way on a monthly basis. Otherwise most of the driving will be city....30 miles per week.
So would it be better to put in the new fluid or leave it as is?
ALSO - I checked the timing belt.....it had the HONDA label on it.....could it be the ORIGINAL belt since new??
I just brought the car 3 weeks ago.
Old Aug 21, 2008 | 08:18 PM
Chris F's Avatar
Default Re: 97 SS with 112k....change or not to change the tranny oil? (integraboi1010)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integraboi1010 &raquo;</TD></TR><TR><TD CLASS="quote">I have been getting mix results regarding whether to drain my tranny fluid and replace them with 3 new qts from Honda.</TD></TR></TABLE>
Auto or manual?
If it's a manual, change it with 2 quarts.
Auto, beats me.
-Chris
Old Aug 21, 2008 | 11:19 PM
ethereal2pt2's Avatar
Default Re: 97 SS with 112k....change or not to change the tranny oil? (Chris F)
i would change the fluids. the MTF does wonders for your tranny if you have stick. and for the timing belt, are you asking if it's possible that the belt could be the same one from when the car itself was made? anything is possible. but it could also be just an oem belt. most likely the latter.
slatermvp
Apr 13, 2012 04:17 PM
DraginTeg93
Dec 14, 2006 02:53 PM
eh2..765
Aug 1, 2006 02:38 PM
JDM H22
Mar 14, 2006 12:12 PM
yaya
Nov 6, 2003 11:22 AM
