LS/VTEC QUESTION!!!
Old Aug 21, 2008 | 04:37 PM
SleepyHatchZ6's Avatar
Default LS/VTEC QUESTION!!!
wats up H-T says that you should use ARP rod bolts with shotpeened rods so do other honda tuning web sites, but a tuning shop that deals with only mainly hondas near me and they said they build LS/V's all the time with bone stock bottom ends revvin at 8Grand makeing power, and my bro was the same way, stock bottom end making power a little past 8grand. Im building my LS/V right now and i cant decide to do stock bottom end or spend money on ARP rod bolts, machining the big end of the rods, and shotpeening the rods let me no what you guys think
Old Aug 21, 2008 | 05:09 PM
Default Re: LS/VTEC QUESTION!!! (SleepyHatchZ6)
Anyone??
Old Aug 21, 2008 | 05:27 PM
Kendall's Avatar
Of course you can slap it together, rev it to 8k, and make power. How long that power is going to last before you spin a rod bearing is another issue altogether.
Old Aug 21, 2008 | 05:28 PM
gotslicks's Avatar
done it both ways
spend the hundee and get the rod bolts and have em machined to spec
dont worry aboot the shot peenin if its all motor
dependin on the cams 8200 will b your limit of power any way
Old Aug 21, 2008 | 05:32 PM
Im plannin on goin all stock for now with a stock 94+ GSR Head you still think my rev limit will be 8200? by the way did you buy the 9mm bolts or the 8mm??
Old Aug 21, 2008 | 05:35 PM
sageuvagony's Avatar
Default Re: (SleepyHatchZ6)
LS block wasn't mean to rev at 8k.
Old Aug 21, 2008 | 05:38 PM
i hear that alot but ive seen stock bottom ends revving to 8k even 8500rpm N/A and Boosted for long periods of time literally years
Old Aug 21, 2008 | 05:39 PM
and its not the block that werent meant to rev that high im pretty sure its the rods and rod bolts bro
Old Aug 21, 2008 | 05:43 PM
slvrcvc93's Avatar
you could always buy the z10 crank girdle it will keep your motor in steady condition will you rev high so that way you have no worries. I could be wrong but i belive they sell it as a kit and it comes with arp main bolts for the entire bottom end.
Old Aug 21, 2008 | 05:45 PM
really?? never heard of it think you could try and find it for me i really wanna put a girdle on it but i dont no where to get one for this block
Old Aug 21, 2008 | 05:49 PM
Default Re: (slvrcvc93)
Yea almost any LSVTEC I see always is revving above 8k.
http://www.youtube.com/watch?v=rv_hxC7mvOU
That one is definitely above 8,200 RPM
Old Aug 21, 2008 | 06:04 PM
slvrcvc93's Avatar
you can read here this the actual person who designed it .
https://honda-tech.com/zerothread?id=162919.
This is where you can purchase it and i belive they also sell there main studs as an entire kit with headbolts but I would call them on that one .
or you can call my local shop in N.J. they use the girdle all the time believe me they will point you in the right direction or you can just buy it directly from them or order it online from z10.
http://www.z10eng.com/catalog/index.php?cPath=21
Old Aug 21, 2008 | 08:42 PM
iamalex1212's Avatar
Nice
go civic type r piston
youll get alot of power
and youll be happy how it will come out
Old Aug 21, 2008 | 09:05 PM
Thateguhate's Avatar
Default Re: LS/VTEC QUESTION!!! (iamalex1212)
I rev my lsv up to 9k and no higher, im not capable of anymore power past 8500rpms really IMO... but i do have a mildly built motor so I've been ok so far.
poppypizza
Feb 1, 2009 04:05 PM
fastcody1
Sep 3, 2008 07:16 PM
g0tgot
Aug 30, 2008 10:59 AM
93SIBLT4NOS
Mar 16, 2004 04:24 AM
stretracr
Jul 10, 2001 06:21 AM
