b18a gearbox in a b18c
Old Aug 20, 2008 | 08:14 PM
vtec1987's Avatar
Default b18a gearbox in a b18c1
Is that possible?
I see ppl putting b18c1 gearbox in LS vtec, so i thought to myself can i use the b18a gearbox in my b18c1 because i gearbox is rooted.
And yes i know the ratio are different, i just want to know if it interchangable so i can get my car back on the road
thanks in advanced
Old Aug 20, 2008 | 08:47 PM
BlueIntegraBoy's Avatar
Default Re: b18a gearbox in a b18c1 (vtec1987)
Yes, the tranny will bolt up to the block
Old Aug 20, 2008 | 08:49 PM
vtec1987's Avatar
yeh i know it will bolt up, will i be able to drive around normally?
Old Aug 20, 2008 | 08:51 PM
Default Re: (vtec1987)
Yes, what are worried about?
Old Aug 20, 2008 | 08:57 PM
vtec1987's Avatar
lol.. nah i dun wana put out the time to do it and it doesnt work properly
Old Aug 20, 2008 | 09:00 PM
digdug18's Avatar
Yes isn't a complete answer, he should have told you the complete truth. The B18A tranny is a cable shifted tranny, the B18C tranny is a hydraulic shifted tranny.
The tranny WILL bolt up, BUT you'll need a hydraulic to cable conversion kit, that runs about $200 or so for the hasport version, to use the tranny. Don't expect a Plug and Play operation.
Andrew
Old Aug 20, 2008 | 09:01 PM
Default Re: (digdug18)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by digdug18 &raquo;</TD></TR><TR><TD CLASS="quote">Yes isn't a complete answer, he should have told you the complete truth. The B18A tranny is a cable shifted tranny, the B18C tranny is a hydraulic shifted tranny.
Andrew</TD></TR></TABLE>
I was going to mention this, but wasn't sure what gen Integra he had.
Old Aug 20, 2008 | 09:11 PM
vtec1987's Avatar
nah the b18a gearbox i have here is hydro, both gearbox looks exactly the same, both have similar shift linkage as well.
Cable tranny doesnt use shift linkage right
Old Aug 20, 2008 | 09:15 PM
vtec1987's Avatar
the b18a gearbox came out of a integra 1994 model.
is that cable or hydro?
Old Aug 20, 2008 | 09:21 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec1987 &raquo;</TD></TR><TR><TD CLASS="quote">nah the b18a gearbox i have here is hydro, both gearbox looks exactly the same, both have similar shift linkage as well.
Cable tranny doesnt use shift linkage right</TD></TR></TABLE>
B18A1 were found on 90-93 Integras. They use shift linkages too
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec1987 &raquo;</TD></TR><TR><TD CLASS="quote">the b18a gearbox came out of a integra 1994 model.
is that cable or hydro?</TD></TR></TABLE>
Anything from 94-01 is hydro. You sure it's not from a B18B1?
Old Aug 20, 2008 | 09:56 PM
vtec1987's Avatar
its came out of 94 integra.
But its b18a for sure, how so i know if its hydro or cable?
Im live in australia if that mite help, probably use different engine code
Old Aug 21, 2008 | 09:41 AM
hondaman1212's Avatar
do you have a clutch cable or a line that goes from by the master cylinder from a resevoir to the front of the radiator by the transmission on the passenger side?that prob sounded confusing what year is your integra?the trans from the 94 is prob hydro trans
Old Aug 22, 2008 | 04:24 AM
vtec1987's Avatar
it has the metal tubing comming from the master cylinder to the transmission,
unrivaledintegra
Jul 17, 2007 11:07 AM
cancer
Aug 16, 2005 07:20 AM
apexinghonda
Jul 2, 2004 08:23 PM
CiViC dRaGsTaR
May 23, 2001 10:10 AM
