Ignition faults or whats going on? help asap!
Old Jul 23, 2002 | 12:49 PM
austrian type-R's Avatar
Default Ignition faults or whats going on? help asap!
Okay, I drove home from work and reved up to 8800rpm with no problems. Then I took the BFG DRAG radials into my trunck and droved with a friend to a straight street. Then we changed the tires and we wanted to measure the acceleration with Gtech. A little burn out (damn, the BFGs pulled my car about 5 meters while the e-brake was fully on)
Okay, we calibrated the Gtech and I started. But once of a sudden the engine stutters above 7000rpm. In all gears at low boost too.
We changed the spark plugs. It was dark already, but we had a flash light. New run, but the same results.
The eninge runs great up to 7000rpm, but then there is something wrong!
Can this be ignition fault? Maybe time for a new distributor cap or something?
Damn, and this 5 days before a huge DRAG event, I'm scared! Guys plesae help out quick!
Old Jul 23, 2002 | 12:55 PM
Default Re: Ignition faults or whats going on? help asap! (austrian type-R)
oh yeah, I have stock ignition, Fuel press was fine too
Old Jul 23, 2002 | 01:07 PM
abraunb16's Avatar
New User
What are the plugs gapped at? How much boost if any are you running?
I guess I can add somemore to this, I was having the same issue. My car was jumping and misfiring starting at 5500 rpms and then again at 6500 and beyond. I thought it was the placement of my 3 bar, since it was close to the battery and fuse box. So I moved it, then I thought maybe it's the MSD 6A taking a crap. So I sent it back and got a 6AL to hold me over. The car does not misfire nor does it surge up top like it used to, but without seeing a dyno plot/chart I'm not going to rule anything else out. I also had my plugs gapped at .030 and spoke to a very smart car guy and he stated that I should close the gap a little more to see if it helps out, so I gapped them at .025 and it doesn't seem to be affecting anything. Morning cold starts are still fine so I'll keep messing with it 'til it's fixed. HTH. Allen
[Modified by abraunb16, 2:07 PM 7/23/2002]
[Modified by abraunb16, 2:42 PM 7/23/2002]
Old Jul 23, 2002 | 06:13 PM
Full-Race Geoff's Avatar
Default Re: Ignition faults or whats going on? help asap! (abraunb16)
for both of u -- sounds a lot like ignitor problems. Swap ignitors with a known good unit and test. This often happens only when the motor warms up, runs perfectly when cold.
edit: let us know what you find, im always interested in hearing solns to weird problems
see: https://honda-tech.com/zerothread?id=230177
youre not alone
[Modified by FFgeoff, 10:15 AM 7/24/2002]
Old Jul 23, 2002 | 11:08 PM
Default Re: Ignition faults or whats going on? help asap! (FFgeoff)
I run max 1.2 Bar boost for 7500 miles not once of a problem. It happend yesterday suddenly. I use NGK copper plugs heat range 7 with plugs stock gap for also 7500 miles with no problems.
Perhaps the plug wires are defect?
Old Jul 24, 2002 | 06:17 AM
... try the ignitor
Old Jul 24, 2002 | 07:47 AM
is the ignitor in the distributor? How does that thing look. I know many other engine parts, but the distributor is new land for me
ralph11sec
Feb 11, 2010 05:04 AM
Cyber ITR
Sep 22, 2006 12:49 AM
kingmonkey
May 14, 2005 09:14 AM
SIK IN DA HED
Nov 12, 2002 09:36 PM
austrian type-R
Jul 24, 2002 04:07 AM
