Suspension & Brakes Theory, alignment, spring rates....
How to set Camber kits right
Old Aug 18, 2008 | 12:07 PM
thanh4o8's Avatar
Default How to set Camber kits right
i have skunk 2 camber kits front and rear. i was wondering how to set them right so i won't have camber. i set them already but it still looks like theres camber
Old Aug 18, 2008 | 01:56 PM
TunerN00b's Avatar
Default Re: How to set Camber kits right (thanh4o8)
Um, you want some camber.
In fact, you want all of the camber you gained from lowering. The slight gain in negative camber from lowering allows better cornering. Why (spend money and) lower the car if you aren't looking for better handling?
Old Aug 18, 2008 | 02:50 PM
ejprimo's Avatar
Default Re: How to set Camber kits right (TunerN00b)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TunerN00b &raquo;</TD></TR><TR><TD CLASS="quote">Um, you want some camber.
In fact, you want all of the camber you gained from lowering. The slight gain in negative camber from lowering allows better cornering. Why (spend money and) lower the car if you aren't looking for better handling?</TD></TR></TABLE>
ditto. and even if you want zero camber on all fours, take it to an alignment shop to do it instead of eyeballing it.
Old Aug 19, 2008 | 10:34 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Take the camber kits off, put stock parts back on, get alignment ASAP with stock parts, sell camber kit parts, and rotate tires every 5K miles.
That's my suggestion. Your tire wear will be fine.
Old Aug 19, 2008 | 10:18 PM
thanh4o8's Avatar
Default Re: (PatrickGSR94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">Take the camber kits off, put stock parts back on, get alignment ASAP with stock parts, sell camber kit parts, and rotate tires every 5K miles.
That's my suggestion. Your tire wear will be fine.</TD></TR></TABLE>
Thing is i dont have the stock control arm anymore. so the camber kits doesnt do ****? So whats wearing out my tires
Old Aug 20, 2008 | 12:15 AM
ejprimo's Avatar
Default Re: (thanh4o8)
TOE. your tires arent pointing straight.
Old Aug 20, 2008 | 10:13 PM
thanh4o8's Avatar
Default Re: (ejprimo)
so when i align my car tell him to leave my camber and just set my toe at 0??
Old Aug 20, 2008 | 11:38 PM
japanjay's Avatar
* B A N N E D *
Yeah tell them to zero out the toe and caster if all you do is daily drive it. And also to make the camber even in regards to the 2 back tires and then the same in regards to the 2 fronts (ie: -3*Rear&-2.5Front). Settings are different for a track only car.
Old Aug 21, 2008 | 11:19 AM
thanh4o8's Avatar
Default Re: (japanjay)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by japanjay &raquo;</TD></TR><TR><TD CLASS="quote">Yeah tell them to zero out the toe and caster if all you do is daily drive it. And also to make the camber even in regards to the 2 back tires and then the same in regards to the 2 fronts (ie: -3*Rear&-2.5Front). Settings are different for a track only car.</TD></TR></TABLE>
so camber is -3 in the rear and -2.5 for front is what i want right?
Old Aug 21, 2008 | 11:29 AM
user 98292739's Avatar
i run -2.5 int eh front -3.5 in the rear.
been going on 3.5 years completely even tire wear...
How is it that its 2008 and people still dont realize when they lower their car they need to get an alignment...
Old Aug 21, 2008 | 02:32 PM
ejprimo's Avatar
Default Re: (The Lobster)
i used to run -2.5 in the front and -1.5 in the rear on street tires and it handled great. you might wanna try -2.0 front and -1.5 rear but i always have a little more camber in the front.
your car's cornering ability will depend on your suspension set-up as a whole so there isnt any magic camber set-up that will cure an ill handling car.
Old Aug 21, 2008 | 06:19 PM
thanh4o8's Avatar
one question. do i have to get alignment every time i lower my car. meaning if i adjust the height i have to do alignment?
Old Aug 21, 2008 | 06:30 PM
02 accord's Avatar
Yes.
Old Aug 22, 2008 | 07:32 AM
Community Builder
If you want your tires to last, then yes.
Old Aug 22, 2008 | 04:39 PM
SportEL's Avatar
Do you have to get an aligmnent if you just adjust the camber on the camber kit?
Old Aug 22, 2008 | 05:41 PM
02 accord's Avatar
Default Re: (SportEL)
Yes.
Old Aug 22, 2008 | 05:51 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SportEL &raquo;</TD></TR><TR><TD CLASS="quote">Do you have to get an aligmnent if you just adjust the camber on the camber kit?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 02 accord &raquo;</TD></TR><TR><TD CLASS="quote">Yes.</TD></TR></TABLE>
i believe not. Since the main point of the alignment is to zero out the toes.
if you eye your camber youll just never know how many degress you are running.
an alignment will tell you that and set it at the desired degree instead of guessing.
you may also be running two different degrees on both sides if you eye it. then i could see some handling negatives but i am pretty sure it wont eat your tires.
Old Aug 23, 2008 | 05:25 AM
Community Builder
Toe will change when you move a camber kit, also.
Old Aug 23, 2008 | 09:57 AM
oh didnt knjow that!
thanks
TonyRomo
Jul 20, 2009 01:24 PM
jda90
Suspension & Brakes
Aug 19, 2005 10:33 AM
kndaqikEG
Feb 20, 2005 05:42 PM
Kyles ej1
26
Nov 19, 2004 06:09 AM
mr tl
Sep 7, 2002 09:39 AM
