B16 Blox IM/BBK TB questions
just finished installing the BLOX intake manifold and a used BBK 62mm TB for a B16A2. put on a fuel pressure guage and regulator. I also put in a walbro 255 fuel pump.WHen i start the car it revs up to atleast 6500 rpm and i shut it off.
No fuel leaks...
So i try this ...
I covered the two ports inside the throttle body one at a time to see if that was the problem. nope...
what else can i do???
the fuel pressure guage reads about 34 or so as it revs up, and about 20 when the key is just turned over...
i did a throttlebody bypass ,,,and the intake manifold had an extra cooling nipple under the main cooling hose, i used a T there and looped it...
3 weeks untill i leave far nationals and i still have a Type R cam to install
Help!!!
No fuel leaks...
So i try this ...
Help!!!
mitchh29
15
Mar 13, 2013 11:53 AM
EF9status
Apr 14, 2008 09:31 AM
obligatory
25
Jan 13, 2008 05:25 PM
