intake and throttle body questions.
So after some looking around i found a few things on the intake manifold and throttle body that had been sealed up. Not sure if they are things that weren't needed after the swap but i figured you guys would know. Here are some pics.
Re: intake and throttle body questions.
the one in the first pic usually goes to your fuel pressure regulator, and the others go to a black box under the manifold for emission purposes, which seems to be eliminated. Go to part source, auto zone, or whatever you have, and get vacuum line caps. They're usally $1 for 8 of them
So basically the little silver contraption attached to the fuel rail almost right in front of the closed off hose in first pic?
Wow i have no clue why the previous owner decided to cap it off instead of just reconnect it. Its only like 5 inches away haha
P/o sounds like a dummy. Unless it was leaking fuel, that's only reason I can think of. If it has fuel in the line the press reg is bad. Id look over the other work p/o did after that's fixed. I'm sure they f'd up other stuff too.
AltimaXX
11
10-24-2009 02:38 PM
95bkeg
05-27-2006 10:10 PM
