jdm dohc f22b install
Old Aug 16, 2008 | 10:48 PM
adam00's Avatar
Default piston install
i have a jdm dohc f22b (same as h23a1 besides the different bore size and the f22 is iron sleeve and h23 is frm) and i want to semi built it for turbo and i was wondering if i could put in forged piston and rods while the motor is still in the car and would i have to replace the main bearing if i dont take out the crank also what gaskets would i have to replace after this install only the head gasket? can i hone the cylinders will the crank in and the motor in the car? also can i just put in forged pistons if the cylinder is worn too much after i hone them (the motor only has 50,000 miles)?? i was also wondering how much hp can stock f22 sleeves handle???
Thanks for your help
Modified by adam00 at 3:07 PM 8/17/2008
Old Aug 17, 2008 | 02:07 PM
adam00's Avatar
Default Re: piston install (adam00)
bump
Stopsign32v
Engine Machining & Assembly
Jan 10, 2018 02:34 PM
adam00
Aug 19, 2008 06:26 PM
adam00
Aug 3, 2008 05:05 PM
93ludeSi
Mar 11, 2003 08:17 PM
lopey
Aug 16, 2002 04:23 PM
