Viper 1002 H1/12 orange wire
Where do i splice this wire??? I have splice and installed every wire pertaining to a 96 Honda civic hatch. Yet im lost when they say Ground when and it supplies 500ma. Where do i put this wire for a Basic install???????
the primary reason for this wire is to run a starter kill. if you dont have a starter kill or anything else to connect to it then you dont need to use it.
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Use that wire to run a relay to open and close your kill switch on the main relay on the car. This will kill your fuel pump, injectors and part of the ecu. 3 in one shot and is very effective on keeping a thief from starting the car. Also relocate it so a thief cant tamper with it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Christianva »</TD></TR><TR><TD CLASS="quote">so pretty much its a ground for a relay </TD></TR></TABLE> Yes, a ground to one side of relays coil, [#85 or #86] the other side of relay should have "true" ign., [hot in run and start].
94
94
It is the ground when armed wire... So it shows ground when and only when the alarm is armed. The 500ma is the current rating. Since it is so low, you should only use the wire to trigger relays that will allow more current to pass through them.
epicbeats
Jul 29, 2009 12:59 PM
SHG_Wacky
Feb 21, 2007 08:25 PM
VTECAcuraGSR
Apr 10, 2002 12:04 PM
