98 civic remote start ?
Old Jan 6, 2007 | 02:40 PM
boynblue's Avatar
Default 98 civic remote start ?
Ok on the relay you connect. On the relay there is thin blue wire that says to connect to the ingnition switch. Should I connect it to the thick black yellow ingnition wire? Or is there another wire it should attach to? alarm CS2016 DP. On the high current connector there is a thick pink wire to be connected to ingnition wire. I was going to wire the blue and pink together with the ingnition wire. Is this ok?
Old Jan 6, 2007 | 02:51 PM
B18C_EJ8's Avatar
Wait, what? What relay??
What exactly does the manual say about this relay?
Old Jan 6, 2007 | 03:00 PM
boynblue's Avatar
Default Re: (B18C_EJ8)
starter disable
Old Jan 6, 2007 | 03:02 PM
boynblue's Avatar
page 6 in manual
Old Jan 6, 2007 | 03:03 PM
B18C_EJ8's Avatar
Again, what does the manual say? I'm sure it says cut the starter wire, attach one wire off the relay to the key side of the wire you just cut, and the other wire off the relay to the other side of the cut wire.
boynblue's Avatar
Default Re: (boynblue)
http://crimestopper.com/
CS 2016 DP install
also on page 7 you see the pink going to IGN That where I was going to connect the blue relay wire.
Old Jan 6, 2007 | 03:05 PM
boynblue's Avatar
Ya I did that with the 2 orange wires that says to cut the starter wire an connect.
Old Jan 6, 2007 | 03:08 PM
B18C_EJ8's Avatar
Yes, the blue wire is attached to the ignition wire. It provides power to energize the coil in the relay.
Old Jan 6, 2007 | 03:10 PM
boynblue's Avatar
ok got it right. Thanks for your help
Old Jan 6, 2007 | 03:27 PM
fcm's Avatar
fcm
Old Fart
Yes both the blue wire from the relay and the pink wire will go to the cars ign. wire, the blue lead on the relay is for the relays coil, you can also connect the blue lead with the orange that you connected to the starter wires ign. switch side. 94
Old Jan 6, 2007 | 04:24 PM
boynblue's Avatar
Default Re: (fcm)
hey dumb question but for this relay does it matter wich way the 2 orange wires are connected to the starter wire?
Old Jan 6, 2007 | 04:25 PM
boynblue's Avatar
Default Re: (fcm)
gotcha cuz the ign switch will open an close the relay also cool.
Old Jan 6, 2007 | 05:43 PM
boynblue's Avatar
does it matter wich way the 2 orange wires on the relay that are connected to the cut starter wire go?
Old Jan 6, 2007 | 05:49 PM
02 accord's Avatar
No.
Old Jan 6, 2007 | 05:53 PM
boynblue's Avatar
Default Re: (02 accord)
thanxs
Old Jan 7, 2007 | 09:20 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boynblue &raquo;</TD></TR><TR><TD CLASS="quote">does it matter which way the 2 orange wires on the relay that are connected to the cut starter wire go? </TD></TR></TABLE> No, it only matters that you connect the starter output, brown, "downstream" of the starter cut relay. 94
Old Jan 9, 2007 | 02:22 PM
boynblue's Avatar
Default Re: (fcm)
Ya got that one right with the brown wire. Threw me off for a sec tho
wwolf771177
Feb 4, 2014 02:25 PM
Dub C
Audio / Security / Video
Sep 13, 2008 11:49 AM
Maverik4k
Sep 21, 2004 03:02 PM
IgotV-tec!
Jul 7, 2003 04:38 PM
