Ran into a little problem
Old Aug 13, 2008 | 12:21 PM
HitF8's Avatar
Default Ran into a little problem
okay so i had run into a little problem when taking out my motor. I have a 92 civic HB that had a d16z6 in it. anyway i was taking out the passenger side torque mount and the nut thats welded on the inside of the frame rail that you can't get to came apart from the welds and the bolt was just spinning. i had cut the bolt to get it out. I had come up with a plan to weld a nut with a shoulder on it to the outside of the frame rail with only the shoulder of the nut being exposed. its kinda hard to explain but im not sure if this will be strong enough since this car will be a DD with a B16a2 in it. the only other way i think of repairing this is to cut out a area of the rail so i can get a wrench in there to tighten the nut to the bolt. which i really don't want to do. If anyone has run into the problem that i am having right now please post what you did to fix it or feel free to post some ideas for fixing it.
Thanks
sorry if someone has posted something on this all ready, i couldn't find much on searching this.
Old Aug 14, 2008 | 06:07 AM
HitF8's Avatar
Default Re: Ran into a little problem (HitF8)
bump
Old Aug 14, 2008 | 06:28 AM
94CivicSi's Avatar
If you remove the bumper, I think the end of the frame rail is open. Not sure if it's enough room to tack a new nut down or not.
Look into a product called a "Riv-nut" if that's not an option.
Old Aug 14, 2008 | 06:48 AM
HitF8's Avatar
Default Re: (94CivicSi)
okay cool thanks bro
Old Aug 14, 2008 | 06:54 AM
slvrcvc93's Avatar
Default Re: (HitF8)
The torque mount to the trans is not able to be seen from the front if you remove the bumper the rad support is solid there. If you have any worries about motor moving you can just buy the Hasport rear mount or the entire kit. With that you should have no worries
Old Aug 14, 2008 | 07:33 AM
HitF8's Avatar
Default Re: (slvrcvc93)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slvrcvc93 &raquo;</TD></TR><TR><TD CLASS="quote">The torque mount to the trans is not able to be seen from the front if you remove the bumper the rad support is solid there. If you have any worries about motor moving you can just buy the Hasport rear mount or the entire kit. With that you should have no worries </TD></TR></TABLE>
thanks i'll keep that in mind, you think i would have any problems with just one bolt in the mount for now?
Old Aug 14, 2008 | 07:36 AM
slvrcvc93's Avatar
Default Re: (HitF8)
you might get a rattle if it starts taping against the body other than that no
Old Aug 14, 2008 | 07:40 AM
HitF8's Avatar
okay cool. thanks for the info
Old Aug 14, 2008 | 12:00 PM
93egsir's Avatar
This happened on my car. I used to install trailer hitches at a previous job. and I enlarged the access hole on the side of the frame rail and used a handle nut. normally these are used to install trailer hitches on veh with boxed frames that do not have weld nuts from the factory. Check for a local hitch install shop and they may have them laying around
Old Aug 15, 2008 | 05:03 AM
HitF8's Avatar
Default Re: (93egsir)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93egsir &raquo;</TD></TR><TR><TD CLASS="quote">This happened on my car. I used to install trailer hitches at a previous job. and I enlarged the access hole on the side of the frame rail and used a handle nut. normally these are used to install trailer hitches on veh with boxed frames that do not have weld nuts from the factory. Check for a local hitch install shop and they may have them laying around</TD></TR></TABLE>
thanks!
MakeshiftJPN
May 11, 2012 03:03 AM
HitF8
Welding / Fabrication
Aug 13, 2008 12:12 PM
drtysohc
Mar 11, 2008 07:47 PM
tekstyle
Apr 24, 2006 10:06 PM
TEG98
Sep 16, 2002 10:34 AM
