rings?
Old Aug 12, 2008 | 10:12 PM
iwantspeed's Avatar
Default rings?
ok so i think i washed out my rings because i ran a untuned ecu on my freshly built block. do i have to redo the build? or is this fixable? thanks
Old Aug 13, 2008 | 06:23 AM
iwantspeed's Avatar
Default Re: rings? (iwantspeed)
up
Old Aug 13, 2008 | 08:07 AM
turboZChatch's Avatar
what makes you think the rings are washed ??? ALot of smoke
Old Aug 13, 2008 | 05:31 PM
iwantspeed's Avatar
Default Re: rings? (turboZChatch)
yea blue smoke. i hit 5th gear rev limiter yesterday and when i was coming to a stop my car started smoking really bad. and u could smell the oil burning.... brand new honda rings too.
Old Aug 13, 2008 | 06:22 PM
Gus-Gus's Avatar
could be the timing off?
Old Aug 13, 2008 | 06:25 PM
Radim's Avatar
Default Re: (Gus-Gus)
Yeah, i'd say check your timing too, could have skipped a toof.
Old Aug 14, 2008 | 07:30 AM
iwantspeed's Avatar
Default Re: (Radim)
ok. but the car runs fun. just smokes.. still has hella power. ill let u know when i get home from work.
Old Aug 16, 2008 | 06:32 AM
redsolturbo's Avatar
Default Re: (iwantspeed)
check your pcv system. blocked valve will force crankcase into the cylinders and sometimes oil etc.
you install the oil control ring in the right way up? (im assuming the honda ones have the lip on them like some aftermarket) were the cylinders honed with a honeing stone to the correct 60 degree cross pattern? also did you seat the rings in right away? ring gap set and rings set in the correct position?
any of the above will cause excessive oil burning.
Old Aug 16, 2008 | 07:24 AM
fireant's Avatar
Default Re: (redsolturbo)
A leakdown test will tell you exactly where the problem is... rings, valves, stem seals.
Old Aug 16, 2008 | 07:52 AM
beana's Avatar
i had the same problem with an old nissan pathfinder i used to have ,they are famous for that.
you don't need to rebuild ,but first do a compression test to get a baseline
next take an oil can with the squirt thingy , and squirt a few squirts directly into the cylinder ,turn it over a few times(unplug the coil so it doesn't get any spark)
then run another comprssion test ,it should be higher
if it isn't check the cam timing
Old Aug 19, 2008 | 07:34 PM
iwantspeed's Avatar
Default Re: rings? (beana)
so i had in between 205 and 220 all the way across and in cylender 3 the leak down test was at 12 percent when the rest were at 4 percent. thats what my mechanic told me..
Destructive-
Aug 7, 2009 02:10 PM
MoreBoost!
Jan 31, 2008 10:26 AM
H9Omega
16
Dec 14, 2006 06:28 PM
N20civicB18
Oct 25, 2004 06:55 AM
tominos
22
Feb 18, 2003 08:55 PM
