how hot does your water temp run when under a lot of boost
what kinda numbers you guys get and under what boost?i'm curious to know about your setups also,radiators slim fans etc?anyhelp would be great.
I stay at about 180 F, with stock radiator and one 11" slim fan. Without the fan the temp was the same, You only use the fans when the car is not moving or moving slow.
how do you check if your thermostat is broken? my stock temp guage goes a lil past half way with turbo... also where do you buy a lower temp thermostat? thanks
jdmspoonitr
Oct 13, 2006 05:10 PM
turbotime
Nov 14, 2005 12:45 PM
