High Oil Pressure
Old Aug 9, 2008 | 04:38 PM
GReddy_Civic's Avatar
Default High Oil Pressure
Just turbo'd the civic and the oil pressure gauge is reading 80lbs which is way too high. Any thoughts?
Old Aug 9, 2008 | 05:32 PM
non-VTEC's Avatar
Default Re: High Oil Pressure (GReddy_Civic)
more details.....
80psi at idle?
over 3000rpm?
hot or cold?
Old Aug 10, 2008 | 06:05 AM
Default Re: High Oil Pressure (non-VTEC)
It was at 80psi on startup and after about 4 min it still really hadn't change. It's mobil1 5w30 and was about 70 degrees outside and yes, it was 80psi at idle and no, not over 3000rpm
Old Aug 10, 2008 | 07:03 AM
non-VTEC's Avatar
let the engine idle for a good 15min or so....or even drive it around. as long as it does not keep climbing up passed 90+ psi i would say it's normal.
most good working honda oil pumps will see 70-80psi (depending on the accuarcy of the gauge) on a cold start with a fast idle of 1500-1700rpm. it should drop down to 15-20psi at idle (750rpm) after about 10min of driving.
Old Aug 10, 2008 | 09:48 AM
1992Si's Avatar
Yes, that's to high for the turbo.
You need to put a restricter in the oil feed line. I like to use a shut off valve, set it about 1/4 open and remove the handle. You can buy one at the local hardware store and some fittings and plumb it in.
Here; This has a pressure sending unit in line too. The copper line is a ice maker line for a freezer.
Old Aug 10, 2008 | 02:01 PM
Default Re: High Oil Pressure (1992Si)
you would say thats too high even after only being on for 3 min, just changing the oil, not having it on for a week, and also having to force oil through all the new lines? just asking, didnt want that to sound mean
Old Aug 10, 2008 | 03:24 PM
1992Si's Avatar
Turbo's only like to see about 30-40psi oil pressure
Old Aug 14, 2008 | 10:51 PM
xelloss's Avatar
What's the normal oil pressure reading for a mostly stock D16Y8 engine??
would it be around 50 psi all the time? no matter cold or not engine?
Old Aug 22, 2008 | 04:39 PM
My psi was around 50 when i was driving around. Now its closer to 80 all the time, not really sure what it is.
Old Aug 22, 2008 | 08:25 PM
dtapia's Avatar
Default Re: (GReddy_Civic)
sounds like a restriction what was installed besides the turbo did you install a oil plate for the supply or ?
Old Aug 22, 2008 | 08:34 PM
just an oil feed line from stealthmode performance
Old Aug 23, 2008 | 08:36 PM
dtapia's Avatar
i would test the pressure with a oil pressure gauge something is not jiving.maybe a faulty oil pressure gauge in the car ?
TeamSeanFTW
Mar 15, 2011 06:41 PM
soontobeboost
Jan 6, 2007 06:22 AM
AsSanitySlipsAway
12
Aug 18, 2006 06:29 PM
1.8
Mar 26, 2005 12:17 PM
dominate9
Oct 18, 2003 12:10 AM
