Head gasket question
Well I am about to drop in a jdm d15b into my 94 civic si, I searched around a bit but cannot find the answer i am looking for, what is the thinnest head gasket I can safely but on my motor?
I would like to bump the compression up a little, I know it will not be too much but the higher the better right... If I can get it around 10.1 with just the head gasket that would be fine by me. And what is the stock thickness?
Thanks
Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Danpeal »</TD></TR><TR><TD CLASS="quote">Well I am about to drop in a jdm d15b into my 94 civic si, I searched around a bit but cannot find the answer i am looking for, what is the thinnest head gasket I can safely but on my motor?
Thanks</TD></TR></TABLE>
Somebody will have to back me up on this because I'm not entirely 100% sure.
Though I'm pretty sure the thinnest you can get OEM is a Y8 3 layer head-gasket and remove the middle layer.
After that, look at Hondata head-gaskets, I'm pretty sure they make thinner ones. Not sure of the sizing of either, though.
