Help with GSR!!!
Old Aug 8, 2008 | 06:26 PM
SL0-hatch's Avatar
Default Help with GSR!!!
Well yesterday, I did a headgasket change on my GSR motor that's in my hatch without resurfacing the head. It had overheated a while back but i risked it anyways. plugged everything back together and now it won't start. Then found out that i didn't have any compression. The compression is reading around 0-10 in the first two cylinders and around 30-40 in the 3rd and 4th cylinders. Then i took it apart and had the head resurfaced and got another headgasket and redid the timing for the second time. I know for sure that my timing is good and that my headgasket is on the correct way. Then tried starting it up again and it didnt start. I then rechecked the compression and its reading around the same thing as the first time. What could be wrong? I need help ASAP!!!!
Old Aug 8, 2008 | 06:29 PM
Kendall's Avatar
You did make sure the top of the block was good and smooth did you not?
Old Aug 8, 2008 | 06:32 PM
SL0-hatch's Avatar
Default Re: (Kendall)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall &raquo;</TD></TR><TR><TD CLASS="quote">You did make sure the top of the block was good and smooth did you not?</TD></TR></TABLE>
sort of i break cleaned it and made it as smooth as possible.
Old Aug 9, 2008 | 01:36 PM
SL0-hatch's Avatar
Default Re: (SL0-hatch)
help me people!
Old Aug 9, 2008 | 01:41 PM
94EG8's Avatar
Seagull Management
Default Re: Help with GSR!!! (SL0-hatch)
Did you blow out the holes in the block that headbolts go into, if theres any oil or coolant in them the bolts will hydrolock and you wont get an accurate torque. any valves stuck open?
Old Aug 9, 2008 | 04:22 PM
slambedcivic's Avatar
Default Re: Help with GSR!!! (94EG8)
head gasket installed correctly? did you actually use a straight edge to check the block? did you spray anything on the headgasket prior to install?
Old Aug 11, 2008 | 06:04 PM
Anti-Drama Queens's Avatar
did u adjust the valves? make sure the compression gauge is working correctly. i've had a few compression gauges take a crap on me.
Old Aug 11, 2008 | 09:46 PM
SL0-hatch's Avatar
no i didnt blow out the holes in the block, no valves stuck open.
yes headgasket is on correct, didn't use a straight edge to check the block, and didn't spray anything on the headgasket.
i did tighten the little screws on the rockers a little. just by looking at it. no instrament used to measure it though.
Old Aug 11, 2008 | 09:49 PM
OMGWTFBBQ!'s Avatar
Sure your timing isn't 180 degrees off?
Sounds like you may have incorrect torque readings on your head studs. I would clean the threads and re-torque everything.
Old Aug 12, 2008 | 02:58 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SL0-hatch &raquo;</TD></TR><TR><TD CLASS="quote">no i didnt blow out the holes in the block, no valves stuck open.
i did tighten the little screws on the rockers a little. just by looking at it. no instrament used to measure it though.</TD></TR></TABLE>
youve answered your own question. You need to do the proper valve adjustment.
protopro88
Jan 17, 2012 10:10 AM
TcUiRvBiOc
Feb 22, 2009 04:32 PM
DUHC
Oct 14, 2008 06:41 AM
limpy
Aug 8, 2004 11:02 AM
chris@cfranklins
Dec 8, 2003 06:25 PM
