what compression piston should i order????? help.
Old Dec 7, 2003 | 10:46 AM
chris@cfranklins's Avatar
Default what compression piston should i order????? help.
im using a gsr block and a type r head and i need 10.0:1 or 9.8:1 what compression should i order.???????????????
Old Dec 7, 2003 | 01:26 PM
Bnjmn's Avatar
Default Re: what compression piston should i order????? help. (dilsnickracing)
what is your planned setup? What are you planning on doing with the car? Tell more.
Old Dec 7, 2003 | 02:39 PM
Default Re: what compression piston should i order????? help. (Bnjmn)
83mm gsr turbo. what is the compression i need to order
Old Dec 7, 2003 | 05:05 PM
11psiTurboSI's Avatar
I go with 9:1cr
Old Dec 7, 2003 | 05:18 PM
btleier's Avatar
Default Re: what compression piston should i order????? help. (9psiTurboSI)
It all depends what you want.... I'm going with 9.8:1 to keep slightly higher compression, but in all reality you could always have a lower compression and run more boost to make up for it.
Old Dec 7, 2003 | 05:45 PM
accordfreak's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dilsnickracing &raquo;</TD></TR><TR><TD CLASS="quote">im using a gsr block and a type r head and i need 10.0:1 or 9.8:1 what compression should i order.???????????????</TD></TR></TABLE>
haha i've been contemplating the same thing for the longest time.
Old Dec 7, 2003 | 05:56 PM
Rickyh93's Avatar
Default Re: what compression piston should i order????? help. (accordfreak)
We are running 10:1 and 28psi looking to go 35psi in a couple of months. I like the higher compression 9:8 or 10:1.
Old Dec 7, 2003 | 05:57 PM
Default Re: what compression piston should i order????? help. (Rickyh93)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rickyh93 &raquo;</TD></TR><TR><TD CLASS="quote">We are running 10:1 and 28psi looking to go 35psi in a couple of months. I like the higher compression 9:8 or 10:1. </TD></TR></TABLE>
what's the most boost you can run with just pump gas?
Old Dec 7, 2003 | 07:24 PM
btleier's Avatar
I don't know if there is a particular number, it's all about where you start to lean out and/or knock
I'd say 20 on pump gas is the highest I would go.
Old Dec 7, 2003 | 08:04 PM
bottlefedb18c1's Avatar
Default Re: what compression piston should i order????? help. (btleier)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by btleier &raquo;</TD></TR><TR><TD CLASS="quote">I don't know if there is a particular number, it's all about where you start to lean out and/or knock
I'd say 20 on pump gas is the highest I would go.</TD></TR></TABLE>
it all depends on your cr
Old Dec 8, 2003 | 05:35 PM
Default Re: what compression piston should i order????? help. (bottlefedb18c1)
no no no no no no i have decided to run 9.8 or 10 already i just need to know since im using a type r head not a gsr how this will affect the cr you know since the combustion chamber is.
Old Dec 8, 2003 | 06:25 PM
Revi's Avatar
Your talking about how much will the Type-R head affect or change your 9-10 compression ratio? If both heads are the same (but we know they are not) as far *** the valve chamber measurements, the compression shouldnt change.
Thrashin
Aug 10, 2004 02:41 PM
1.8T_EG
Jul 6, 2004 08:27 AM
YOSOLO CRX
13
Nov 13, 2003 08:53 PM
K20 EG
Jun 17, 2003 11:26 AM
