Speedometer problem: Guage does not go beyond 40mph CEL 17
I have a 95 civic VX hatch. stock. guage does not read above 40mph on the hwy and sometimes it falls down to 20mph.
I get a check engine light 17 (VSS).
Replaced the VSS and the Speedo head.
Still problem exists.
Anyone share a similar story and how they fixed it?
1995 Civic VX.
Check Engine light Code 17 Vehicle speed sensor.
Replaced Vehicle Speed Sensor, speedometer cluster and VSS wire harness "plug".
Removed Speed sensor assy and checked plastic gear on speed sensor and in the transmission. No gears are broken.
I looked underneath the vehicle and did not see any wires or wiring looms dmged or rubbing against any brackets, etc.
Im thinking ECU..
anyone else want to give some thought?
Im thinking ECU..
