4040 prop valve
Old Aug 8, 2008 | 05:57 AM
monicle's Avatar
Default 4040 prop valve
can someone give me a diagram showing which port on the 4040 valve goes to which wheel? all that comes up in searches is debate on which valve to use and a schite load of for sale or wanted ads.
Old Aug 8, 2008 | 08:19 AM
specoperformance's Avatar
Default Re: 4040 prop valve (monicle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by monicle &raquo;</TD></TR><TR><TD CLASS="quote">can someone give me a diagram showing which port on the 4040 valve goes to which wheel? all that comes up in searches is debate on which valve to use and a schite load of for sale or wanted ads.</TD></TR></TABLE>
it all plumbs up just like the stock one, the valves should look identical
Old Aug 8, 2008 | 11:42 AM
monicle's Avatar
Default Re: 4040 prop valve (specoperformance)
ok car was given to me with a shaved engine bay, no brake lines and a loose valve, hence the need to know which go where.
Old Aug 10, 2008 | 06:20 AM
monicle's Avatar
anyone?
Old Aug 20, 2008 | 12:11 PM
downeyballz's Avatar
bump this topic, because i would also like to know
Old Aug 20, 2008 | 12:53 PM
JdelMsolG's Avatar
Default Re: 4040 prop valve (downeyballz)
bump, because someone here can help.
Also, Just search for some pictures of rides with integra brake swaps.
Look for the money shots and see if you can identify your issue from the bay shots
Old Aug 31, 2008 | 12:40 PM
PhrequenC's Avatar
Default Re: 4040 prop valve (JdelMsolG)
bump i need to know also!
Old Aug 31, 2008 | 01:23 PM
BlackDeuceCoupe's Avatar
HT White Ops
Default Re: 4040 prop valve (PhrequenC)
Um...
Isn't there an 'R' w/ arrows cast into the valve body on two of the holes (same side of the valve body - upper n' lower)?!?!?!?
Old Aug 31, 2008 | 02:48 PM
mental1's Avatar
Do a part search on http://www.majestichonda.com for brake lines should be enough to tell you what you need.
Old Aug 31, 2008 | 03:34 PM
slvrcvc93's Avatar
Default Re: (mental1)
I hope this might help
GarretCRX
May 4, 2007 02:50 PM
95blackEG
Apr 25, 2006 10:28 PM
JokerTypeR
10
Sep 27, 2005 05:33 PM
Shift_Fast
Feb 19, 2005 11:24 AM
