4040 prop valve
1 Post
4040 prop valve
can someone give me a diagram showing which port on the 4040 valve goes to which wheel? all that comes up in searches is debate on which valve to use and a schite load of for sale or wanted ads.
Re: 4040 prop valve (monicle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by monicle »</TD></TR><TR><TD CLASS="quote">can someone give me a diagram showing which port on the 4040 valve goes to which wheel? all that comes up in searches is debate on which valve to use and a schite load of for sale or wanted ads.</TD></TR></TABLE>
it all plumbs up just like the stock one, the valves should look identical
1 Post
Re: 4040 prop valve (specoperformance)
ok car was given to me with a shaved engine bay, no brake lines and a loose valve, hence the need to know which go where.
Re: 4040 prop valve (downeyballz)
bump, because someone here can help.
Also, Just search for some pictures of rides with integra brake swaps.
Look for the money shots and see if you can identify your issue from the bay shots
HT White Ops
Re: 4040 prop valve (PhrequenC)
Um...
Isn't there an 'R' w/ arrows cast into the valve body on two of the holes (same side of the valve body - upper n' lower)?!?!?!?
Do a part search on http://www.majestichonda.com for brake lines should be enough to tell you what you need.
JokerTypeR
10
09-27-2005 05:33 PM
