ECM/PCM reset
Old Aug 8, 2008 | 03:58 AM
welp's Avatar
Default ECM/PCM reset
A while back while driving I hit a pretty deep puddle of water and had some problems
with my engine sputtering and stalling intermittently. My check engine light goes on and I figured
if I let whatever got wet dry out everything would be okay. My car runs fine now but the engine light is still on and I was told resetting the ECU/ECM might fix the problem. In my civic manual it says I need scanning tool or PGM tester from Honda to clear the memory and then to remove a backup fuse to perform the reset. I was wondering if clearing the memory is necessary or if there is another way to do it without getting Honda's scanner.
Old Aug 8, 2008 | 04:25 AM
welp's Avatar
Default Re: ECM/PCM reset (welp)
Problem solved, All I did was disconnect my battery and checked out the fuse for my ignition coil.
Everything is normal now.
rosyjazz
May 4, 2007 08:51 PM
wragen22
Mar 11, 2005 02:04 PM
bicho
Feb 18, 2004 02:50 PM
Jackalassassin78
Jun 25, 2003 08:44 AM
blazin99si
Mar 12, 2003 04:00 PM
