clutch master or clutch slave cylinder?
Old Aug 7, 2008 | 11:13 AM
hYbRiD EeEkAy's Avatar
Default clutch master or clutch slave cylinder?
so i was driving to dade two nights ago and my clutch pedal felt like it was sticking and then all of a sudden i lost all the pressure in the pedal and couldnt get the car in gear. i guess the clutch is still engaged and wasnt able to disengage? anyway, got the car home, clutch master cylinder reservoir was almost empty.. no signs of leaking from the slave or master and no signs of leakage under the pedal. traced the hardline running to the slave and found signs of leaking where the hardline turns to a soft line.
filled the reservior, tried pumping the pedal and no pressure. tried bleeding the system and it was fine.
any ideas as to wether it is the slave or master?
Old Aug 7, 2008 | 11:27 AM
Hanmin's Avatar
if its leaking where the line turns soft, theres your problem. check the hose and check the connection.
Miracle11
Feb 13, 2011 06:38 PM
obuhmyuh
Apr 19, 2008 02:14 PM
anewfoundkevin
Sep 2, 2004 04:56 PM
Pandahatch
12
Aug 24, 2004 07:48 AM
Lei Siew Long
Oct 22, 2002 10:43 AM
